WTB - 00vi w/ all 5th gen and q45 tb
hi, as some of you know i just got my 3rd 4th gen the other week while i was home on leave. im currently back here in iraq for another 6 months or so and id like a boat load of parts to play with when i get back. its going into the shop pretty soon to get the kinks worked out. then probably wheels and a bbk after that... ill have custom led tails and retro'd r34 made while im gone hopefully too.
but as far as performance goes, id like to get ahold of an 00vi with all the 5th gen parts accept the tb... from what ive read you can use a pathfinder tb but it takes a couple mods. while the q45 is an easy swap? correct me if im wrong people! i cant seem to find the how-to/info guide on the 00vi any more either
so is the q45 or pathfinder better on the 00vi? or just stock. im just going on the general idea of more air + more fuel = more power lol... but anyways, if someone out there has the FULL setup let me know as im interested! and by full, im talking down to the sensors, new bolts, and all that... i dont want to have to go source stuff out when i get home to put it on...
oh and where is that page on the for sale stuff with the guy that always has them! i tried to find it again but no luck...
so is the q45 or pathfinder better on the 00vi? or just stock. im just going on the general idea of more air + more fuel = more power lol... but anyways, if someone out there has the FULL setup let me know as im interested! and by full, im talking down to the sensors, new bolts, and all that... i dont want to have to go source stuff out when i get home to put it on...oh and where is that page on the for sale stuff with the guy that always has them! i tried to find it again but no luck...
haha, lots of reading on that one! i also read the q45 on 00vi post... that ranting was funny. but like you said, seems to be to large for anything that isnt running crazy numbers. i guess a pathy tb will do for the swap then, even if i do sc/tc in the future! what comes along with using the pathy tb? should i use its maf, and what kind of adapter plate, if any, is needed? wiring differences?
With the pathy tb, you can either drill new holes in the tb or buy an adapter plate. The only person I know of that makes the adapter plates is Steven Max. If you can, pick up a pathy tb with the IACV housing and IACV as well. The 5th gen and pathy IACV are interchangeable (I'm running a pathy IACV in the 5th gen IACV housing ATM). Your stock MAF will be fine. I'm almost positive the 4th gen TPS will work in the pathy tb. It's beneficial to port the UIM to match the pathy tb. The stock MAF can also be ported to compliment the pathy tb. Someone here was/is selling a ported MAF and claimed gains of 10hp after tuning. You can also bypass the coolant on the tb, that's just personal preference.
i feel like im competent enough to do all the wire work, i just dont want to try and learn the harness for a first time go. i mod power supplies on computers and all that stuff all the time. custom cables and what not. fix amps, tvs, and tons of electronics but ive never delt with a cars harness
yeah ive thought about getting me a dremel kit when i get home and doing a little porting... and id assume just using the pathy tb, iacv, and maf would be a better combo than trying to port ours or anything... do you port the upper and lower intake manifolds or just the upper at the tb? oh and redrilling some holes shouldnt be a problem on the tb but if the adapter plate looks better i may go that route... id just like it to look as oe and clean as possible. and whats the deal with the connectors? should i use our iacv because of the connector, or could i mod those to work?
Car harnesses really aren't all that different, I used to mod consumer electronics all the time before I found the org
Ive read that people have worn out many sanding drums when using a dremel to do some porting. You don't have to port the upper and lower intake manifolds, but it wouldn't hurt to do it. At the very least, port the upper at the tb. http://kyleb.semanticalsyntax.com/00VI_Manual_v1.pdf Page 7 for the IACV Connector.
and on the OP subject. i was able to find someone to work with me and they have allll the parts id like to buy so if mods would like to close this one up thats cool with me!
PURCHASED!!! ty everyone!
MAXSE5SPD
Sep 17, 2022 04:00 AM
t6378tp
Sep 29, 2018 04:27 PM
Violator
Sep 9, 2015 10:14 AM
