smell of burned oil and check engine light
Last night I started my car and immediately I smell burned oil coming through the vents but the car runs just fine. Later I checked the oil and it was a little low but not bad so I topped it off. Well now this morning I'm getting a check engine light. I wont have time to go get it checked out until after work but what do you think it could be, considering the burned oil smell?
Got it checked during my lunch break, pulled 2 codes 1st is the small leak evap system or whatever, I didn't bother to write that one down it's no big deal. 2nd is P1800 - VIAS Control Solenoid Valve Circuit. The guy tried explaining it to me but I don't think he really knew himself, Can you guys fill me in on what exactly the VIAS control solenoid valve is and what it does? and what do I check? or do I just replace the solenoid?
So the hose going into the manifold had a split on the bottom so I cut the split section off and reconnected it. Electrical connection looks fine, other hoses look fine. I disconnected the battery to see if the cel would go away but it does not. does this mean the solenoid needs replaced?
http://www.courtesyparts.com/14956w-...-p-193708.html
wow $150 I cant find anyone else who has one tho. If I drive the car with a bad solenoid for a few weeks will I be hurting anything?
will this work
http://www.ebay.com/itm/Nissan-Infin...item56494f2290
CorollaULEV
30
Aug 9, 2021 08:11 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
