smell of burned oil and check engine light
Old Jun 22, 2010 | 06:45 AM
rosader's Avatar
Last night I started my car and immediately I smell burned oil coming through the vents but the car runs just fine. Later I checked the oil and it was a little low but not bad so I topped it off. Well now this morning I'm getting a check engine light. I wont have time to go get it checked out until after work but what do you think it could be, considering the burned oil smell?
Old Jun 22, 2010 | 06:48 AM
NmexMAX's Avatar
dot dot dot ...
Have you recently changed the oil and perhaps spilled some on some exhaust components, causing it to burn? Your oil cap still on there?
Old Jun 22, 2010 | 07:06 AM
rosader's Avatar
I actually haven't changed the oil in a while (I'm running synthetic) but it's probably about time for a change
Old Jun 22, 2010 | 07:14 AM
matt06's Avatar
check to see if it is coming out anywhere on your engine or if there is buildup anywhere
second, pull the code, that will tell you ALOT more than we already know and then go fromt there
good luck
Old Jun 22, 2010 | 11:54 AM
rosader's Avatar
Got it checked during my lunch break, pulled 2 codes 1st is the small leak evap system or whatever, I didn't bother to write that one down it's no big deal. 2nd is P1800 - VIAS Control Solenoid Valve Circuit. The guy tried explaining it to me but I don't think he really knew himself, Can you guys fill me in on what exactly the VIAS control solenoid valve is and what it does? and what do I check? or do I just replace the solenoid?
Old Jun 22, 2010 | 12:01 PM
NmexMAX's Avatar
dot dot dot ...
This is what it does:
Old Jun 22, 2010 | 12:10 PM
rosader's Avatar
Cool thanks, I will have to check the connection and hoses after work. Where is it located exactly?
Old Jun 22, 2010 | 01:29 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/5th-generat...cuit-open.html
Old Jun 22, 2010 | 07:33 PM
rosader's Avatar
So the hose going into the manifold had a split on the bottom so I cut the split section off and reconnected it. Electrical connection looks fine, other hoses look fine. I disconnected the battery to see if the cel would go away but it does not. does this mean the solenoid needs replaced?
Old Jun 22, 2010 | 07:57 PM
rosader's Avatar
I can't seem to find a solenoid online anywhere. Is this a dealer only part?
Old Jun 23, 2010 | 04:24 AM
bob-lee's Avatar
courtesynissan.com
Old Jun 23, 2010 | 07:23 AM
rosader's Avatar
http://www.courtesyparts.com/14956w-...-p-193708.html
wow $150 I cant find anyone else who has one tho. If I drive the car with a bad solenoid for a few weeks will I be hurting anything?
Old Jun 23, 2010 | 08:18 AM
NmexMAX's Avatar
dot dot dot ...
Make sure that is the problem first. Test it. No, it wont hurt anything.
Old Mar 21, 2012 | 11:26 AM
importcf's Avatar
hate to dig this up but did you find a resolution to the oild smell i have the same issue and it seemed to start after the VIAS BOP install or the Home Depot catch can not sure. no obvious leaks tho
Old Mar 21, 2012 | 07:18 PM
Maximeltman's Avatar
will this work
http://www.ebay.com/itm/Nissan-Infin...item56494f2290
CorollaULEV
30
Aug 9, 2021 08:11 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
