Sponsored by:
Sponsored by: CARiD
00vi swap this weekend. a few Q's
Old Jun 24, 2010 | 10:08 AM
skweaky's Avatar
Can I lean out the A/F ratio somewhat safely without the use of a wideband?(using an Apexi VAFC)
if not
How horrible does the car run untuned with the 5th gen injectors?
if terrible
How frustrating is the drilling nessesary for the hybrid 4th gen LIM 5th gen UIM?
Old Jun 25, 2010 | 10:13 AM
VQ'ed's Avatar
the car runs a bit richer up top but the idle is fine on the AFR aspect. Tune -5% above 3200rpm in wide-throttle gets you in the 13's afr up top.
drilling the 4th gen lower to adapt with the VI has been done by a machinist but I suggest you take the time to find a 5th gen lower, its 100% bolt on.
Do you have 5th gen injector clips?? if not, weld the wires on the injector pins and shut the holes with engine gasket paste. Turning around the 4th gen lower need a grounding wire to be made to ground your front injectors.
keep the questions coming...
Old Jun 25, 2010 | 01:54 PM
hornepirate's Avatar
you can drill the 4th gen lower and use threaded rods to fill the holes vs using a machinist but its a pain
Old Jun 25, 2010 | 03:05 PM
shadyonedeath's Avatar
you'll run REALLY rich...i ran 10 AFR in Open loop without a tune.
And no its not safe, but my VAFC2 tune is all above -8%...but don't blame me if ur **** blows up.
Old Jun 26, 2010 | 09:13 AM
skweaky's Avatar
i am a little confused about the fuel rail adaptation. i cant find a proper writeup on how to make the 5th gen rail work with the 4th gen line. Is it more than just a matter of getting fuel to rail? I read something about a piece that restricts flow that i will need.
Old Jun 26, 2010 | 09:52 AM
http://forums.maxima.org/all-motor/5...1999-se-l.html
Old Jul 26, 2010 | 04:37 PM
Sicarius_Vis's Avatar
Any updates on the swap? I will be doing the swap in the near future. I've been taking my time, prepping the upper IM using shadyonedeath's tutorial.
Old Jul 26, 2010 | 07:33 PM
MoncefA33's Avatar
Get a wideband...
Old Jul 27, 2010 | 09:31 AM
ajcool2's Avatar
Get a wideband...
This.
Old Jul 27, 2010 | 02:25 PM
VQ'ed's Avatar
I ran 11's at 0% correction. I put -5% from 4000rpm to 6600. got 12's...
Old Jan 15, 2011 | 01:46 AM
smx2's Avatar
I have looked through heaps of 00vi threads, and am looking to see if it is possible to use the 5thG LIM with the 4thG rail + inj = fuel reg, but it seems not, until what you have stated..... "if not, weld the wires on the injector pins and shut the holes with engine gasket paste." Please explain a little more by what you mean by weld wires to injector pins and shut the holes with engine gasket paste.
Old Jan 15, 2011 | 09:42 AM
VQ'rInWLA's Avatar
http://tatanko.boredmder.com/00VI.html
Old Jan 15, 2011 | 10:47 AM
maxboy325's Avatar
Originally Posted by shadyonedeath
Yeah good info here with nice pics
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
