Animal attack and 2 speed trans
My Max was running fine one day and inoperable and barfing fluid the next. My wiring harness to the crank position sensor, the crank reference sensor and one trans cooling line were literally chewed off over night by some kind of animal!
After finding and fixing the damage, I now have a trans code 0734 "4th gear wrong ratio". I only have 1st and 3rd gears. I can't find any other wiring damage. HELP!!!
John
John
shes in limp mode, i think. make sure shes topped off with fluid, than reset the ecm. see if it comes back.. otherwise you might have to bring it to a dealer and have the tcm looked at.
Those splash guards are important as you can see. You should get them replaced to aviod this problem again in the future. Now you said you have a code for "4th gear wrong ratio" right? But also you stated you only have 1st and 3rd gears...so what happened to 2nd gear?
limp home mode is 3rd gear.
the tcm keep's the car in 3rd gear when it's in lhm.
does it feel like 4th gear is kinda iffy? - There is no 4th gear attempt at all and the converter also does not lock up, so everytime you let off the gas, the tach goes to idle. It fooled me at first because I thought it shifted and dropped rpm, then I realized I just backed off on the throttle and it was free wheeling.
can you shift into second gear manually?
John
John
ooh.. Theres yer problem... sometimes it can still up trans material and some of it can get stuck in the shift solenoid chambers. This could be the reason.. You might want to look into checking out your previous work, as well as mabey a new tranny.. so sorry buddy.
knight_yyz
Nov 1, 2015 01:34 PM
ef9
Oct 4, 2015 08:43 AM
