Heater/Air fan switch only works on #4
Old Aug 14, 2010 | 10:17 AM
MaximaMark123's Avatar
'96. The fan switch for heat and air only works on the high (#4) setting. It makes no difference if the AC is on or off.
Just a worn out switch?
Old Aug 14, 2010 | 10:36 AM
metalgod3082's Avatar
Your Blower Motor Resistor went bad. You should be able to replace it on your own. Just do a search for blower motor resistor and you should be able to find out how to replace it. I also think you can repair it by soldering part of it if you know how to solder.
Old Aug 14, 2010 | 10:50 AM
Thank you, I'll check it out.
Old Aug 14, 2010 | 02:39 PM
I soldered it and it works fine, thanks.
Old Aug 14, 2010 | 06:35 PM
JtzMax's Avatar
Whatchyou say?
Next time, please use the SEARCH function ... come on people!
IBTL
Old Aug 14, 2010 | 09:30 PM
If I don't know its the blower motor resister I need to search for, how do I search for the blower motor resister? I mean, I know what the problem is but not what caused it. I tried searching for fan switch, air conditioner switch, fan not working etc... to no avail. Lucky for me this nice person put me on the right track and I was able to fix the problem in a few minutes for which I am very grateful.
Old Aug 14, 2010 | 09:34 PM
jwei's Avatar
where did you soldered it? I cannot see where the problem is.
Old Aug 14, 2010 | 10:52 PM
Funk-O-Meter's Avatar
Sometimes a resistor pack going can be symptomatic of the blower motor failing. If the pack fails again and you loose blower speeds you probably need a new blower motor. Other symptoms of a failing blower are occasional needing a bang it with a hammer to get it to start. If you can get to it.
Old Aug 15, 2010 | 01:00 PM
JtzMax's Avatar
Whatchyou say?
Sorry, I'm not trying to be rude, disrespectfull, or inconsiderate. However, this is the (litteraly 30 seconds) search that came up when I put in 'blower motor' ....
http://forums.maxima.org/search.php?searchid=1307998
Not saying it isn't ok to start new threads or anything, but like most things on this site - this has been covered several times. When you search, make certain you have the 'sort results by' set to Relevancy and that should help.
Sorry ta bust your chops.
jerrod99_se-l
Aug 27, 2015 08:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
98nismomax
Aug 13, 2015 12:15 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
