Fuel Pressure Regulator
Old Aug 15, 2010 | 06:24 PM
Justaguy's Avatar
Anyone here has replaced the F.P.R (Fuel Pressure Regulator)?
I have some starting problems and after reading this forum, it seems that changing the FPR might do it....(along with all the EGR cleaning stuff).
To make a long story short,I'm trying to unscrew the two screws that are holding up the F.P.R but they are on sooo tight..I've used PB blaster (tapped it) but it won't budge. I even tried an power tool but I almost stripped out the inside of that screw...I was thinking of heating that thing but I have so much oil and rubber hoses that I'm afraid to attempt it.
Any other tips I could use?
Old Aug 15, 2010 | 07:22 PM
Nopike's Avatar
That is a common problem. Put your phillips screwdriver into the FPR screw and give the end of the screwdriver a good hit with a hammer. It should break the bond. I was having problems with those screws also and this worked like a charm.
My starting problem was caused by the starter not the FPR. If you remove the vacuum hose from the FPR and there is fuel there the FPR is bad if it is dry the FPR is probably OK.
There is fuel there so maybe the heating idea is not so good.
Old Aug 15, 2010 | 07:28 PM
DennisMik's Avatar
I tried to take my FPR off when I changed the knock sensor so I would have more room. But I couldn't get the lower screw out. I got the upper screw off using a small pair of vice grips on the screw head.
Old Aug 16, 2010 | 07:11 AM
Trini Boom's Avatar
+1. Vise grips are your best bet in getting those screws off. Also, if the FPR does not leak into the vacuum line, doesn't mean that its good. I replaced mine anyways and went from over 2 seconds of cold start cranking to less than a second..
Also, I replaced mine with a OEM...your preference in where you want to get yours from.
Old Aug 16, 2010 | 08:24 AM
Justaguy's Avatar
I'm having 2nd thoughts about changing the FPR, I'd thought that since I have everything off (MAF, IACV, thottle) access is a lot easier, but wow, what a workout thus far..
My starter was replaced last month after it literally died on me, car did not turn over, but the other starting problem continued...basically in warm weather only, when the car is cold, the car starts and stalls almost immediately...unless I have the gas pedal pressed down, then it would start.
Old Aug 16, 2010 | 12:02 PM
Trini Boom's Avatar
That is your FPR but why did you remove IACV??? That is no where near the FPR. You need to just remove MAF and throttle body assembly. You are giving yourself more work than you should be doing....
Old Aug 16, 2010 | 01:19 PM
Justaguy's Avatar
I removed the IACV because I'm cleaning out the EGR tube as well...I took it off last night and it was very black and the EGR tube is blocked (I'm going to have fun with that screw I have to hack)
Old Aug 16, 2010 | 01:24 PM
ColombianMax's Avatar
These 3 are your best friends
Here's the sourcehttp://forums.maxima.org/4th-generation-maxima-1995-1999/618096-hard-start-weak-start.html
Old Aug 16, 2010 | 07:53 PM
RA030726's Avatar
I'm nutty for Nissans
Drill them out and replace them with hex heads.
Old Aug 16, 2010 | 11:48 PM
damn you went through all that trouble? I think my way is easier and faster
Old Aug 17, 2010 | 06:19 AM
Justaguy's Avatar
Yeah, I might just drill them...
I'm going to get myself a good set of pliers and see if I can get anywhere.
Old Aug 17, 2010 | 06:24 AM
cashoit's Avatar
WHen u replace, can u post the results? Im curious to know
Old Aug 17, 2010 | 04:44 PM
Trini Boom's Avatar
Not pliers, Vise grips...you will only round off the head with the pliers...
As far as drilling them out, that's a bit extreme. The screws are not heavily torqued but are seized up due to corrosion.
Old Aug 17, 2010 | 06:00 PM
Justaguy's Avatar
Okay I got them both out!
Well actually I called on my mechanic friend to help me out..in less than 1 minute he had them both out.
He started with the top screw and he placed a fine chizel (sp?) between the screw and the FPR, gave it 2-3 taps with a hammer, then he unscrewed it.
For the bottom, he just tapped the FPR from a few sides (to giggle it I guess) then with some pressure and a good screwdriver, he took out the second screw.
I was tapping the hammer with the screwdriver in the screw...oh well, experience I guess.
SO it's out!! Finally!
Old Aug 18, 2010 | 06:52 AM
Nopike's Avatar
I was tapping the hammer with the screwdriver in the screw...oh well, experience I guess.!
With the screwdriver in the screw worked for me but I could see using the chisel if that did not work.
Old Aug 18, 2010 | 09:57 AM
Glad you got it out but I really don't see what the big fuzz was about... There's plenty of room to access the screws and you had plenty of suggestions
Old Aug 18, 2010 | 11:25 AM
Justaguy's Avatar
Correct, but those suggestions didn't work for me..almost did. The mechanic showed me new ways to get those screws out..for next time
The problem wasn't with the access..
"To make a long story short,I'm trying to unscrew the two screws that are holding up the F.P.R but they are on sooo tight..I've used PB blaster (tapped it) but it won't budge. I even tried an power tool but I almost stripped out the inside of that screw...I was thinking of heating that thing but I have so much oil and rubber hoses that I'm afraid to attempt it."
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
