Map/Baro Solenoid Air/Vacuum Sources?
Old Aug 20, 2010 | 03:20 PM
OC_Nooby's Avatar
Hey all
I was wondering if you guys could help figure out where/what source of air goes to the lines of the Map/baro solenoid. I also have another solenoid that was running along the Vacuum Gallery that looks exactly like the Map/baro solenoid (not the EVAP solenoid).
Here is the picture...
K5T46581 7924 : Map/baro Solenoid
K5T46583 7923: Another Map/baro Solenoid????I'm not sure?They look the same...
A: ?
B: to boost solenoid (IIRC)
C: ?
Old Aug 20, 2010 | 04:26 PM
OC_Nooby's Avatar
Im only asking because I didn't understand this picture...I also couldn't find where/how the other solenoid was hooked up/whats its purpose.
Old Aug 20, 2010 | 05:57 PM
OC_Nooby's Avatar
I should also add I did removed the vacuum gallery, to clean up the bay a little (hoses were disconnected/cut a while back). So I want to hook back both solenoids (minus the EVAP solenoid). Something tells me ill be shooting in the dark on this one...
Old Aug 20, 2010 | 06:05 PM
Kevlo911's Avatar
Kevlo for President
One is vac, one is abso press, one is breather/openair?
Old Aug 20, 2010 | 06:14 PM
OC_Nooby's Avatar
Does it matter which is which? I also have another one that's identical but it sits in the middle of the vacuum gallery (has green connector) the Map/Baro has a brown connector.
Old Aug 20, 2010 | 06:16 PM
Kevlo911's Avatar
Kevlo for President
I'll check in the morning if you can wait.
Old Aug 20, 2010 | 06:31 PM
OC_Nooby's Avatar
I'll wait. Was going to try it tonight but since it hasn't been plugged in for like half the summer I don't really care. Just trying to clean up/ remove the engine lights. Thanks Kevlo
Old Aug 21, 2010 | 08:43 AM
Kevlo911's Avatar
Kevlo for President
A and C connect to the metal hoses, Im not sure which is the vac and where they both go.
http://www.nicoclub.com/FSM/maxima/1997/EC.pdf
EC10 has the main diagram, just follow the lines. Might be easier to take in paint and color the lines
But to me it looks like A goes to filtered air source and C goes to vac
Old Aug 21, 2010 | 05:07 PM
OC_Nooby's Avatar
Thanks Kevlo, its a little more detailed then what I had...Still gonna be plug and pray
Old Aug 22, 2010 | 02:01 PM
bamboomerang's Avatar
c= in - barometric air source from intake box/tubing
b= out - goes to absolute pressure sensor.
a= in - needs vacuum source (UIM)
Old Aug 22, 2010 | 06:11 PM
OC_Nooby's Avatar
THANKS!!!!
Earlier this morning I tried both with vacuum, no Map/Baro Code. Then did as you said no Map/Baro code. Inew the 2 vacuum sources wasn't right...just wanted to see what would happen.
Thanks again to the both of you!
Old Aug 22, 2010 | 08:06 PM
RA030726's Avatar
I'm nutty for Nissans
Late to the party but here are all 3:
Going by your A,B,C; A is the single metal nipple, B is the middle plastic nipple, C is the last nipple.
Green solenoid controls EGR.
A- Vacuum from intake manifold
B- Back pressure transducer, AKA EGR valve
C- Fresh air source, from intake resonator
Brown solenoid controls Boost/MAP sensor.
A- Vacuum
B- Boost sensor
C- Fresh air source
Black solenoid control EVAP.
A- Fresh air source
B- Vacuum source with check valve
C- Evap canister purge control valve, AKA little black disc on intake manifold
The vacuum gallery is the most over engineered pile of metal spaghetti in the world. Its way confusing and overly complicated. I removed all of it years ago and mounted all 3 solenoids and boost sensor to a metal bracket near the ABS actuator.
Old Aug 22, 2010 | 08:42 PM
OC_Nooby's Avatar
Thank you very much...You have saved me so many headaches...
Old Sep 12, 2010 | 02:58 PM
slapnuttery's Avatar
Map/Baro sensor
I think I may have a similar issue with my map/baro sensor. I started having a stalling issue only when coming to a stop. Acted like it was starving for fuel. Here's the list of things I replaced: IACV, fuel pump, TPS, Cam PS. Took TB off and thoroughly cleaned it. (Thanks Pohmr for great right up). Can I test map/baro like most sensors? As long as I'm getting X volts then it's good? It's starting to stutter and try and stall even under acceleration. Only happens when engine up to normal temp. Doesn't happen every time it's driven. I'm at the end of my rope. Any ideas?
Old Jun 28, 2012 | 02:51 PM
nhfreeman's Avatar
how does the fresh air source thing work? where do you get the fresh source from?
Old Jun 28, 2012 | 07:31 PM
RA030726's Avatar
Either leave it open to the air or connect it to the mid pipe.
Old Jun 29, 2012 | 10:34 AM
nhfreeman's Avatar
so when you say vacuum you mean a hose directly off the manifold not the airbox/intake? the reason why i am askin all these questions is because i am currently fixing all vacuum lines and i just want to make sure its right the time. and after a lot of research this is probably the most helpful info i've come by.
aw11power
Oct 10, 2021 04:57 AM
homeofbacon
Sep 23, 2015 07:17 PM
conansriver
Sep 11, 2015 10:26 AM
Hdnseek
Sep 9, 2015 05:55 AM
