why does my 0-60 seem horrible?
Okay, I picked up my 98 maxi SE with about 98k miles. Its automatic. Being curious, I decided to test out the VQ30. I floor it,and it picks up like a ****(you all know that torque), which gets me to about 40. Then it shifts to 2nd and it takes about 4 mississippis to get to 60. In simple terms, my 0-60 takes, on average, about 11 seconds. Is this just stock, or is something up in my engine causing this?
1st and 2nd gears redline pretty quick if your flooring it. I think 3rd gears that takes the longest to redline.
1 mississippi
2 mississippi
3 mississippi
Seriously...
If your curious on how your car performs, put it on the dyno or take it to the track.
Report back your findings and get out of Mississippi.
2 mississippi
3 mississippi
Seriously...
funny shytuse a stopwatch and then time it. should be around 7 secs. Check for KS issues. 11 secs is 4 cylinder times.
problem.... 0-60 in 4 Mississippi,
Solution... Go to Maine, "smaller state", try it there, maybe you can go 0-60 counting Maine
Or, just change your oil, change your plugs, check knock sensor, air filter, FUEL FILTER?, tire presure, is your exhaust backed up?,untedected misfire?, car going into a semi limp mode?, coil packs have the right resistance?, are any vacuum hoses cracked or disconnected?, what motor oil are you running just curious, are you driving with your 2 front windows down?, was a/c on when you did it?, do you have a bunch of trash, junk, CINDERBLOCKS, extra transmissions, speaker systems?, FAT CHICKS, or anything that mayweigh your vehicle down?, have you checked your tranny fluid?, are the shift solenoids in the tranny any good?, are your gears shi**ing on you?, Are you sporting 30" rims?, And last but not least........ IS YOUR THROTTLE CABLE ADJUSTED CORRECTLY? <- i mean anything can happen right? But just incase
I mean, those are most of the things i can think of that may cause your "sudden" decrease in such "pwer" you crave.. i dunno,someone chime in after me. :P
Thanks man...
BTW... "when did they stop teaching math in schools" is a quote from njmaxseltd that was posted in another thread. I just thought it was funny.
As far as your acceleration... Put on a basic intake (cone filter) and exhaust, and you will see a huge difference. Well worth the little money its gonna cost you to do. Good Luck!
Thanks man...
cone filter doesnt help it changes distance air moves and may change power band ever so slightly. i think your thinking of the 00vi
Incorrect... So tell me then, a cold air intake changes the distance of air flow since it runs down into a fender right? So by that statement you are saying that even a cold air intake will decrease output over a factory intake setup??? I don't think so
Its not the distance of airflow, its how much more air you can get through your engine without resistance.
more air in is better k&n drop in filter does that, i use one. Changing the length of the intake changes its resonance frequency which will "change" power curve a bit not increase it. cold air is like 1 hp with an NA car our stock intakes are pretty well balanced.
im glad theres a 0-60 thread i did my 0-60 with a stopwatch. my time was 8.3 seconds. i think thats pathetic. now, let me tell you my mods, acchhem, 99 se, auto, loaded, 209k miles no fat chicks, new plugs, in good repair, custom cai, headers, y pipe, factory cat, cat back, knock sensor was replaced. is my factory gauge that far off? 60-up is increadable though
"What the @#$% is the point of spending a ton of money on an intake for a bolt-on NA car?" My understanding is that the intake is a vacuum and the shorter the distance the better, sure colder air is more dense, but how much of that is actually making it all the way to the engine? The stock intake mid pipe is a helmholtz resonator and was very well designed for the 4th gen 3.0. Basically speaking, it is very good at reducing turbulence which allows the air to flow freely into the manifold. A poor intake design for our cars would introduce more turbulence into the intake and manifold, decreasing performance. (It does sound damn good though.)
The crackhead has spoken.-crackhead
(Good enough for my 15th post in almost 5yrs? I think so...)
(I loves me sum smilies!)
(a post without smilies is a wasted post.)-crackhead
I you have a limited amount of funds, start with Y pipe for exhaust, and then a less restrictive muffler.
This is a great thread for me right now! I'm a double newby here, first Maxima (98 se 5 spd, 187k) and a new member so I cant post yet. The second day I had the car the check engian light came on and I pulled in to an autozone for a check of the ECU. I got P0301 and P0325. Sounds like the knock sensor is a common problem area. I thought mine was running ok until I did an unscientifc test of my 0-60. I got 12 Mississippi's. KIDDING, I really got just over 9 seconds by my stop watch. This was with premium fuel. Then I let a friend drive it that has had several of these Maximas and he confermed it seemed weak to him. Since i'm new to the forum, can someone teach me how to research these codes and how to repair them on the forum? I know it upsets the elders when you just ask a question that has been asked before and the ansewer is somewhere in the fourm. Thanks guys
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
laparka66
Aug 6, 2015 09:36 AM
