can i change control arm bushings or only whole arm.
ok i changed this same control arm about 2 years ago and it went bad a year later and now it has gotten to the point it makes a LOT of noise when i turn the wheel and shakes pretty bad on high and is popping and creeking.
can i only change the bushing or only full arm? i paid like 200 bux for it and makes me mad same side is bad again, their was a crank seal oil leak their but is fixed now.
95 maxima gxe or gle.
$200 for a LCA? I hope that was OEM.... You can replace the bushings and buy a ball joint and press it in. I was thinking of getting the Dorman's from AutoZone as people say that they are good and I could get a lifetime warranty on it as I am strapped for $$$.
This is the front left: http://www.amazon.com/Dorman-Solutio...4605849&sr=1-1
If you need the front right: http://www.amazon.com/Dorman-Solutio...gy_auto_text_b
For the price autozone charges for one you can buy both sides...
wow, thats pretty cheap. and the ball joint still looks in great shape its just the connecting bushings give my tire a bit of play and is causing popping noises its gotten so bad.
how much are those bushings and how do they go in cause i thought it needed to be pressed in.
You can get the es poly control arm bushings for around $35 from autozone. Or you can try out these: http://forums.maxima.org/group-deals...shing-set.html
If you need to get them pressed in (and removing the old ones is sometimes a PITA too) then you might want to just pick up the assembled arms from amazon...unbolt, swap, and done.
You can buy generic bushings at Advanced Auto for like 5.39 each x2 and you need to get them pressed at a machine shop or a shop with a press. I paid 10 bucks x 2 because I removed the old busing myself but my local machine shop charges 20 per LCA
Oh yea, you need to ask for 86,87,88 Maxima LCA bushing, any of those years works because they "dont" make them for the 3rd or 4th gen
We have the full front end kits to redo everything if you are interested. Just an idea.
http://forums.maxima.org/group-deals...cp-import.html
im looking for the cheapest route for now so i may just pick up the bushings from autozone and have them pressed in.
im thinking about trying those mentioned above for 79 bux. no since in replacing the arm if it still looks new and has good ball joint on it.
so you guys saying i need to go in autozone and ask for lca bushings for a 88 maxima and that will work?
I need to replace the control arm bushing as well but the only ones I can find are the ones on the front pin. I cant find the rear pin bushing on the control arm.Why is this? I would like to replace the whole control arm but I need the cheapest route right now.
You said you just replaced the LCA about 2 years ago and your having problems with it again. That doesn't sound right unless it was a really cheap LCA or you really beat on your ride. Have you looked into the rest of you front steering/suspension 2 see what's going on. Even an aftermarket LCA should last you longer than 2 years. Sounds like something else is going on and is fuucking up your steering/suspension. I just felt I had to suggest this cause I didn't see anything posted on this thread about the cause of your lower control arm to keep going.
So did you ever get the bushings or what?
If you read the OP's comments, he mentioned an oil leak that screwed up the replacement part.
Lifetime Warranty to boot!
