Link to WSP subframe install PICs
Here's a link to some PICs of the install of our subframe connectors on Matt93SE's car. PICs of the stage 2 cross bracing will be posted in a few days. This link can't be found on our web site. First shipment goes out on Wed.
http://warpspeedperformance.com/subframe2.htm
Matt promised to post a little later.
Dan WSP
Dan WSP
"We also put a set on the WarpSpeed 96SE which will get the Stage 2 this week. To me it feels like a combination of swaybar and fstb all in one." - From the WSP Site
That really sounds nice. So it tightens the car up alot then huh? Will you still be able to attach a rear sway bar on there?
SuDZ
SuDZ
SuDZ
SuDZ
And yes, you'll be able to keep the rear sway bar on, asccording to Dallas. he said theyll be putting it back on their 96 this week sometime.
Is it able to be installed by most people like other bolt ons?
SuDZ
SuDZ
If you drill to install them, you'll have to drill completely through the floorboard of the car and into the cabin.. then you'll have to remove your seats and pull up the carpet in the interior just to get to the bolts. not a fun thing to do.
As for why they must be installed on a lift is because the frame will flex on a 2 post lift, or simple jackstands. have you ever tried to open your door while you had the left front of the car jacked up? if you install the SFCs like that, the car will be stuck like that until you remove the SFCs.
doctorpullit
Oct 11, 2015 10:28 AM
