one problem after another with my maxima
Ok i went out and started my maxima this morning and it was idleing higher then normal and everytime i put it in drive or reverse it would shake and shut off. this happen to anyone else?? and ideas??
Whats TPS?? And yes the MAF is plugged in. It only does it when its cold out. When its hot it dont. Or if i let it sit long enough for it to get cold. Ugh really not likin my max right now.... Now my trans is messing up to the over drive is sputtering when i let go of the gass about 40 to 60mph......
Also, motor mounts could be going bad.
TPS is throttle position sensor.
I also have a similar problem with the rumble at idle.
ok well i got my tranny flushed and that fixed that problem and the cold start problem is still persisting i have a check engine light on and it says egr but i put a brand new one on and got it erased and it came back on. and its still doin the same thing so i guess ill go buy the TPS tomorrow and see about cleaning an maybe replacing the IAC.
HOPEFULLY everything will work out lol
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
yat70458
Aug 3, 2015 01:16 PM
