not charging only when cold WTF? new alt
so i'm getting battery and brake light when cold start for about 5 min..
then lights vanishing then for a while ABS light appears then disappear....
i did measurement:
start engine -12,03 V
3-5 min later magically 14,30V ?
i replaced alternator maybe 2 months ago, i made belt very tight so i don't think it can slip,
my suspicion
1)i messed up alt connector little bit (2 wires) but it was fitting tight anyway...
2)can belt be too tight or something?
3)could it be because bad groundings? so far i only cleaned battery negative to frame to engine...
any ideas?
i did measurement:
my suspicion
any ideas?
i cleaned battery connectors, checked belts with no luck...
also have problem with locate OEM grounds other than battery (-) to engine and one next to washer fluid container. All search result is about installing aftermarket ground kits, but how about clean oem ones? where they are?
would it be electric short somewhere? what device is running only when car is cold and only for a while?? wouldn't it make sense?
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
