RI 2004 Volvo S60R AWD 6Spd
Posting this up for a friend...trying to get rid of it
2004 Volvo S60 R AWD 2.5L I-5 Turbo (no shaft play, no oil leaks no burning oil), 6 speed M66 manual transmission
Titanium Gray Metallic over Nordkap (navy blue) Leather interior
75,xxx Miles
Originall built in and imported from Belgium
1 of just 1930 produced and imported in 2004
Every option except navigation (power heated seats, CD changer and Dolby surround, Rain Sensing wipers, fog lamps Xenon HID Headlamps, moonroof, dual zone climate control). Dealer serviced since new at Boston Volvo Village (have contacted them with the VIN to verify). All original books and tools including original window sticker. All recalls performed and since I personally have owned it, it has been serviced by a specialist shop (the only tech allowed to touch the car worked for steingold volvo for 10 years).
Exterior is a 9/10. Typical stone chips on the front bumper, a couple of door dings on the passenger side, and a couple paint chips on the rear bumper cover. A bit of rash on one or two wheels but nothing you could see without looking for it.
Interior is a 9/10 also. The car is mint aside from the driver's seat, which has the typical wear and also is suffering from the wear on the dye that was actually a recall. Depending on your local dealer, they may still replace the seat cover under the recall. Rear seat is absolutely perfect, as is dash, console etc. Trunk is like brand new. Car comes with both carpet floor mats as well as rubber all weather mats, including rubber trunk mat. The all weather mat set alone would cost you well over $300.
18" pegasus alloy wheels with Michelin Pilot Sport 2 tires (should last another summer, I'd recommend a good set of A/S or Snows for the winter)
13" Brembo brakes on all four corners with 4 piston calipers up front (60-0 in 120ft!)
FOUR-C Active Chassis Control (electronically switch between comfort / sport / advanced suspension settings)
Recently replaced with OEM parts:
-Drivers side headlamp ballast (a typical issue on the 04 models. Resealed with Silicone to prevent same issue)
-MAF sensor (another typical issue on the 04's)
-Air filter
Also has a few aftermarket goodies:
-IPD Polyurethane Upper Engine Mount bushing / Lightweight aluminum bracket
-IPD Polyurethane Lower Transmission Torque Arm
-IPD 'R' Ram air intake tube
-Nokya 2500k (golden yellow) foglamp bulbs
-Custom painted engine cover (this I did myself. Looks good, but not perfect)
-TME Catback Exhaust
The only thing this car needs is an alignment, headlight ballast and a fuel filter. The ballast costs about a hundred bucks and can be replaced in under an hour. The fuel filter is $20. Those two simple things are the reason I'm selling it so cheap.
Get those two minor things taken care of, and you will have a perfect, excellent condition example of a very rare and sought after vehicle. It's a blast, but I've got student loans coming up and I'm looking to eliminate as many bills as I can.
This car is a bargain at 13,000 or nearest reasonable offer. The only other ones you will find may be a bit cheaper but will have much higher miles, or will have lower miles and be very pricey. Again, only 13,000 or nearest reasonable offer. BUY IT TODAY AND I'LL REDUCE THE PRICE EVEN MORE!
Call JOE at 401-935-9000
75,xxx Miles
-Air filter
just to help with the sale, when stock these cars are basically dead even with a typical 3.5 swap 4th gen on the highway. tune and downpipe and they gain another 60hp. my buddy has one and I've driven it extensively (including at the track), both stock and now that his is modded.
they are super comfy and quiet too, and handle awesome especially when you add a rear sway bar. the active suspension that you can adjust at the push of a button on them is sweet, and the sound system is freakin sick. brakes are off the charts too.
spencerwh1
Jun 30, 2016 05:44 AM
hayne
Oct 5, 2015 11:53 AM
