Possible Auto Heat/AC Control Unit Issue:
Old Nov 9, 2010 | 09:54 PM
Pearltt's Avatar
I was driving my car the other day when I noticed that only the heat was working. If i put the climate down to 60 with the AC on it's still shooting out 90 degree heat...Also the sensor that shows the outside temp is showing ----F. It started at 104 and worked its way up to 127F and now it only shows ----F. Is this the Auto Heat/AC Control Unit or something else...Could it also be something as stupid as a fuse somewhere in the car to cause this?
Old Nov 10, 2010 | 05:18 AM
BlackMacks's Avatar
Check the online FSM, sounds like you've got two failures:
One is the ambient temp sensor, the other would be your "door mode" actuator or motor, which switches the door in your blower housing to either give a/c or heat. Sounds like it's stuck on heat.
There's a diagnostics/error code "tree" you can access right there on your auto display screen, but you need the pages from the FSM to confirm what's failed.
Starrider
Dec 18, 2015 04:43 AM
EdRomo86
Sep 12, 2015 07:49 PM
