Static Problem
Old Nov 12, 2010 | 01:26 PM
djdavebse's Avatar
Static Problem
ok so since i received this car in February every time i use the car cut it off when i open the door and touch the metal outside i get shocked which im sure is static this doesnt happen all the times but sometimes is does and im tired of it so i dont know whats causing the problem can anyone help?
Old Nov 12, 2010 | 06:33 PM
Lemonhawk's Avatar
It could be the clothes you ware. You can also buy a grounding strap to attach to the car. They are light and while moving are blown up out of the way, but when you stop they drop done and attempt to dump the static charge build up. There also my be some anti-static spray that could be used. From the description, I think the grounding strap should work. A little searching on the net should locate who sells them.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
