wheel wobble wtf
Old Nov 13, 2010 | 10:18 AM
BLACKKILA.GTR's Avatar
wheel wobble wtf
ive been having this issue for a while now.. at first i thought it was my caliper.. then my wheel bearing but changed both and the same issue is there..... pretty much my rear right wheel wobbles.. i changed out the caliper rotors pads wheel bearing.... and the problem is still there... trying to find a solution to this issue.. any imput??
Old Nov 13, 2010 | 10:19 AM
Stormzusmc's Avatar
hub assembly
Old Nov 13, 2010 | 10:46 AM
luvlexus101's Avatar
If the bearing was gone for long enough it messed up inside the hub too.
Old Nov 13, 2010 | 12:05 PM
i changed out the whole hub assembly...its a new bearing aND HUB ASSEMBLY
Old Nov 13, 2010 | 04:21 PM
Froggmann's Avatar
When you jack up that corner can you move the wheel at all? How about the rear beam? What condtion is the strut in? What about the mounting points for the strut?
Old Nov 13, 2010 | 04:35 PM
mista0406's Avatar
what about a warpped rim
Old Nov 13, 2010 | 06:14 PM
datsunzcar84's Avatar
Do you have stock or aftermarket wheels ? I know with aftermarket wheels sometimes you need to use hub centric spacers.
If you have stock wheels make sure there is no corrosion on the mounting point where the hub meets the wheel.
If there is no corrosion on the wheel take it to a tire shop and have them put it on their balancer to see if the rim is bent.
Hope this helps!
Old Nov 13, 2010 | 07:04 PM
2000_MAXIMA_KING's Avatar
Bent rim? Or maybe rear beam is off.
Old Nov 13, 2010 | 07:45 PM
chrome91's Avatar
i know my front wheels had a half inch wobble, replaced the control arms, tie arms, and ball joint and its gone
Old Nov 14, 2010 | 09:43 AM
maximase86's Avatar
I love lamp.
There could be a chance the spindle might have been damaged by a bad bearing/hub assembly.
Old Nov 14, 2010 | 12:29 PM
gow do you replace the spindle?
Old Nov 14, 2010 | 03:01 PM
914Max914's Avatar
proabbly the hub mine did the same i needed a new hub nd bearings
Old Nov 15, 2010 | 06:55 PM
got new hub and bearings.
i got that but it didnt solve the issue
Old Nov 16, 2010 | 08:00 AM
maximase86's Avatar
I love lamp.
Have you checked for play after you installed the new hub/bearing? If there is still play it could be the spindle.
From what I see from the drawings the spindle appears integrated with the rear beam (though I'm not 100%, you would need to look).
Old Nov 16, 2010 | 10:33 AM
I believe you are right the spindle appears to be a part of the beam.
A quick check on everythingnissan.com seems to confirm this .
Old Nov 16, 2010 | 10:34 PM
ah nooooo. is it hard to replace the beam?
Old Nov 17, 2010 | 09:46 AM
Prophecy99's Avatar
+1 i would check this easy thing first
Old Nov 20, 2010 | 06:45 PM
ight bearing is goin bad again..smh and the wheel is not the issue...
DOES anyone know where i can get the whole beam from along with watever bushings i need for it.. this job is gonna suck smh.... i wish i wouldnt of kept on putting this issue off..
Old Nov 20, 2010 | 09:39 PM
Dudeman's Avatar
+2
I had wobble at high speed, I have aftermarket rims, like everyone else. After hub-centric rings the wobble reduced. I found out that one rim was bent, so I took it to one of those rim truing shops. They did a good job, and less wobble. After new tires, even less wobble (I figure the tires had wobble worn into them, if that makes sense). After taking the wheels off myself and doing the feet-on-the-wheel plus every-other-nut method, the wobble is almost all gone.
Hub rings were 15 bones at Discount Tires, rim truing was 125 bones for one rim. Making sure the wheels were put on correctly was free .
Old Nov 20, 2010 | 10:03 PM
foodmanry's Avatar
Da Roller Coaster!
Rotate front and rear wheels on that side and see what happens...
Old Nov 21, 2010 | 12:38 AM
i did.. the rim is fine
HOKUSMAX
Nov 13, 2017 04:34 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
