How to add turnsignals to miror
Old Nov 13, 2010 | 09:23 PM
cajun1104's Avatar
Hi all,
So this afternoon I was bored, so I decided to add turnsignals to my mirrors. The first step in my process was to buy some flat laying amber led strips from autozone.
Then I removed both mirrors from the car.
next, remove the tape that is around the rubber barrier.
then remove the three screws the hold the mirror together.
next, drill a small hole(just big enough for the wires) in the bottom of the mirror.
Now fish the wires through that hole and under the mirror
then run the wires through the rubber barrier. and reapply the electrical tape.
then, solder a six led strip to the wires and apply silicone and shrink tube.
Apply the strip to the bottom of the mirror.
Install back onto the car and wire to a turnsignal fed of your choice.
I have not wired them in yet due to it started to rain on me. but this is a nice preview of how they will look.
Old Nov 13, 2010 | 09:27 PM
I like it! Never thought of doing that, good job.
Old Nov 13, 2010 | 09:53 PM
kcxd35's Avatar
Can I see more pics of how that looks at a slight distance and far away??? more pics!!!
Old Nov 14, 2010 | 03:27 PM
cajun1104's Avatar
http://www.youtube.com/watch?v=JkHJYM9-eZo
here is a short vid of the leds. Not sure how to input videos.
Old Nov 14, 2010 | 03:57 PM
2 GO B4's Avatar
Very nice job!!!
Old Nov 14, 2010 | 04:27 PM
Old Nov 14, 2010 | 04:28 PM
They look really good. Now remove those ricey pinstripes..
Old Nov 14, 2010 | 05:34 PM
luvlexus101's Avatar
LMAO I was just thinking the same thing
Old Nov 14, 2010 | 05:38 PM
jowo9's Avatar
LED turn signals =
Pinstripes =
Old Nov 14, 2010 | 05:44 PM
Grand_hustle17's Avatar
i like the work that was put in and the creativity of coarse, but isnt the cefiro side mirrors have that built in? (not the exact same but you get what im saying)
Old Nov 14, 2010 | 07:36 PM
Mr. Brett's Avatar
I actually really like this setup.
It's very stealthy, and you won't be able to see the LEDs unless you're right up on the car.
Which is nice, IMO, because I can't stand the blinkers that are on the outer plastic of the mirrors. I think it looks cheap.
Old Nov 14, 2010 | 07:39 PM
Waxima's Avatar
I had bad expectations for this when I saw the title of the thread and then "Autozone" in the first sentence. I was pleasantly surprised when I got down the the pictures. Nice work.
Old Nov 14, 2010 | 11:14 PM
kcxd35's Avatar
I love it, I'm so doing this... Thank you for the video...
Old Nov 15, 2010 | 11:55 AM
shdwonthsun's Avatar
this is sweet!! ill prob just use the 2 outermost led's. could you snap a pic of what you see from the driver's seat for us?
Old Nov 15, 2010 | 12:19 PM
mista0406's Avatar
Very stealthy man great work
Old Nov 15, 2010 | 02:15 PM
cajun1104's Avatar
Yeah, Ill add them later on tonight.
Old Nov 15, 2010 | 02:24 PM
essential1's Avatar
My axles cry for mercy...
+1. lol. I was expecting to see the strips stuck to the outside of the mirror with a trail of wires leading back into the cabin. Nice job.
Old Nov 15, 2010 | 03:36 PM
6SPD02SE's Avatar
Nice!! I like it!
Old Nov 15, 2010 | 04:10 PM
cajun1104's Avatar
Driver side view from driver's seat
passenger side view from driver's seat
Old Nov 15, 2010 | 07:20 PM
BoDenKai's Avatar
wow im actually considering this
Old Nov 15, 2010 | 07:36 PM
zero2sixtyZ's Avatar
You embarrass me.
Not bad. What's bad are those pinstripes...
Old Nov 15, 2010 | 08:53 PM
incubusjohnny's Avatar
where did you wire them to? did u run the wires under the fenders to the sidemarkers or tap into the fuse box somehow?
Old Nov 15, 2010 | 09:01 PM
jowo9's Avatar
No way zero! I think you need some pinstripes. Do them in white, and maybe make them a bit wider than the OP's hehehe
Old Nov 18, 2010 | 12:41 PM
how did you get them to stay with all of the crud in our mirrors?
and also did u you put them on the back of the mirror or on the bottom (im referring to inside the entire mirror housing)
Old Nov 18, 2010 | 12:53 PM
cajun1104's Avatar
to get them to stay I cleaned the mirror with alcohol and also applied a dab of supper glue at the ends. I mounted them to the bottom of the housing right under the mirror.
Old Nov 18, 2010 | 01:01 PM
looks good! im gonna do this! except i think im gonna put them at the outermost place on the inside of the cowlings, sunk back behind the mirror so i cant see them inside
Deckdout2's Avatar
Play with my balls
Most of the turn signal leds that I've seen on the side view mirrors are on the back side, and if the people inside the car see the light blinking it's very minimal. Most are also suppose to be directed to allow oncoming traffic to see them as well. I know that there are some that are actually embedded in the glass and you see them in plain view, but I don't think they're as bright as the ones you've installed. I guess what I'm trying to say is that, try not to let the cool factor/brightness distract you from actually looking in the mirror or turning your head to make sure the coast is clear before you proceed.
Very nice none the less. An OG member, MaximaPolak put individual leds underneath so it can been seen almost in a 360* manner.
btw, not sure if this has been mentioned but get rid of that damn pinstripe!
Old Nov 18, 2010 | 01:03 PM
so what your saying is they are mounted on that lip thats there, not where it drops down inside? sorry i cant tell from the photos
Old Nov 18, 2010 | 01:06 PM
Deckdout2's Avatar
Play with my balls
More details with pics.
http://forums.maxima.org/5th-generat...s-5th-gen.html
Old Nov 18, 2010 | 01:28 PM
cajun1104's Avatar
Yes, they are mounted directly under where the mirror usually sits in the housing. about .25 inch from the outside edge.
Old Nov 18, 2010 | 01:36 PM
cajun1104's Avatar
If your were to look at what ford does in there F-150's. they are almost exactly what i have done, except that they are not as stealthy when not in use.
Old Nov 19, 2010 | 09:21 AM
nissandrvr98's Avatar
umm...you and me both.
slick.
Old Nov 19, 2010 | 09:23 AM
l3fty's Avatar
nice idea. good work looks good.
Old Nov 19, 2010 | 09:49 AM
5 ltr. beater's Avatar
i dont know why all the naysayers are saying the strip doesnt look good. i really think that it looks awesome. i would totally consider doing this.
Old Nov 20, 2010 | 07:59 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
not the light strip. the pinstripe on the side of the car.\
and its amazing that that other kid was beaten with a stick for doing these, and members are praising this set up years later for something similar...woooow.
doesnt look bad in my opinion. dont know if id go through the hassle :/ im lazy lol.
Old Apr 3, 2011 | 08:24 PM
danielduran89's Avatar
Wiring
Hey Bro what did you wire the LED's to?
Fbana41
Aug 29, 2016 12:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
