new alternator, car still whines after install
i get a nice high pitched whine, everythings working, no codes, maybe the higher amperage alternator, ( went to a 125 ) has something to do with it??? car runs fine...
Is there a whine all the time?
nope, quiet as a church tonight when i went to run some errands, i think its more when its cold and she sits for a day or 2. i had the belts adjusted twice cause i could smell rubber burning.
Could be the bearings on the AC compressor, mine made an awful smell and a faint noise before totally seizing.
well, im pretty sure bearings dont smell like burning rubber. what did it smell like? im thinking idler or ac compressor, until it totally starts going nuts, im not replacing. can you replace compressor bearings and/or re-grease them?
I would also check your battery voltage.Some times when a battery is low the alternator is working harder to compensate for the low battery voltage and whines.A fully charged battery after it has been sitting for a while should read at least 12.6 volts.Good luck.
yeah, my optima yellow top is from 07, the drivers side hid blinks on real slow the first time, but then is fine. thats why i got a higher amperage alty, tryin to help the battery out handle the load. before the hid setup i never had a problem with the alternator, but i think its the combination of that and the system i have crankin in the car. and she's 16 years old and bo longer a virgin
The only way you can replace the bearings is if you pull the whole pulley off the car and swap them from a junkyard compressor. I tried doing this but it is nearly impossible to get the old pulley off without damaging them.
Try the screwdriver/stethoscope trick. Get a long screwdriver (18-24 inches long) and press the tip on a suspect part (like the altenator housing) and put your ear on the screwdriver handle. The closer you are to the source of the noise, the louder it will be at the end of the screwdriver. There will always be low pitched "grumbling" background noise everywhere you try but a high pitched sound will come through. I did this when my altenator bearing was going bad.
Lakersallday24
Jun 16, 2019 01:35 AM
Superbform
Aug 11, 2015 08:10 PM
00 Max
Aug 4, 2015 07:09 PM
