List of batteries that are drop in replacements on the 7th gen.
I'm replacing the battery on my 7th gen and am starting to look at what fits and what doesn't. From what I've seen, there aren't a lot of choices due to the reverse post setup. (Thanks Nissan!
So, with that being said, if anybody knows of a battery that fits in the stock location without requiring a total rework of the wiring, post it here! I've got a question out to XS Power to see if they have suitable replacements and I'll update this thread as soon as I know.
Keep in mind that I'm a car audio junkie and do have a system in my Max so I haven't shopped standard replacement batteries.
Here's my list so far...
Odyssey 34R-PC1500 (requires height adapter from what I can tell)
http://www.odysseyfactory.com/battspecs.html
Optima RedTop 34R (requires height adapter, but it's included)
http://www.optimabatteries.com/optim...dtop/index.php
Interstate MTP-24F
http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-MTP-24F(Automotive+Truck).aspx?dsNavigation=Ntk%7eSear chGroup%7cmtp%2f-24f%7c3%7c%2cNy%7eTrue%2cNtpc%7eDisabled%2cNs%7epr oduct+Type%7c101%7c1%7c&Title=Mega-Tron+Plus+24F+Automotive+Battery+++85+months+++800 +CCA
Sears DieHard Platinum P-5, Group Size 35
http://www.sears.com/shc/s/p_10153_12605_02850035000P
)So, with that being said, if anybody knows of a battery that fits in the stock location without requiring a total rework of the wiring, post it here! I've got a question out to XS Power to see if they have suitable replacements and I'll update this thread as soon as I know.
Interstate MTP-24F
Having a hard time finding the actual specs for the OEM batt, but Interstate makes a battery they say will fit with the following specs. Its not as powerful as the Odyssey, but looks almost an inch taller
Product ID: MTP-24F
Amps: 1000
Cranking Amps: 1000
Cold Cranking Amps: 800
Voltage: 12
Termination: A
Pro-rata Warranty: 85
Weight: 44.4
Width: 6.88
Length: 11
Height: 8.75
Product ID: MTP-24F
Amps: 1000
Cranking Amps: 1000
Voltage: 12
Termination: A
Weight: 44.4
Width: 6.88
Length: 11
Height: 8.75
Optima RedTop 34R (requires height adapter from what I can tell)
Product ID: MTP-24F
Amps: 1000
Cranking Amps: 1000
Voltage: 12
Termination: A
Weight: 44.4
Width: 6.88
Length: 11
Height: 8.75
Product ID: MTP-24F
Amps: 1000
Cranking Amps: 1000
Voltage: 12
Termination: A
Weight: 44.4
Width: 6.88
Length: 11
Height: 8.75
Thanks for verifying that. I'm pretty sure it comes with the Odyssey to. Seeing as I'm leaning toward the Odyssey, I'll let everyone know soon.
http://www.interstatedealers.com/ibc...mmon/specs.pdf
Also seen this photo that shows the terminal in the proper location
Full spec sheet for the MTP-24F. FWIW Optima and Interstate are the same company
Sweet. Thank you! DHP is a great battery from what I hear.
I remember that "back in the day" we were told to run Red Top under the hood and Yellow Top as our second battery. Now they're saying just run Yellow Top everywhere and you're good. I actually started out looking for a Yellow Top but they don't make the 34R in Yellow so I didn't list it here. I'll probably just steer clear of Optima as I'm trying to move to something like an AGM. If someone finds a compatible yellow top I'll be more than happy to list it though.
According to my invoice the Sears PN for the Diehard Platinum they recently installed is 22850035 with a description of Btry, DHPLATINUM GRP 35. I looked at the battery to see if there was a different PN on the physical device and could not discern one.
Thank you sir. Added to the list!
Have you looked at Stinger? Not sure what would work would have to call as their online catalog is horrible.
I'm thinking the SPV35 might work...?
http://www.google.com/products/catal...d=0CDsQ8wIwBQ#
http://www.stingerelectronics.com/
New Battery
I just bought a brand new 2010 Maxima SV Premium/Navigation 3 weeks ago. A week after that I installed two 12" subs and a Rockford Fosgate Power T5002 amp (sux I can't change the radio in it). Anyways, a few days ago I was driving at night and had my music bumping pretty loud and I noticed the HID's we're dimming with the bass notes. I found that very odd because my other vehicle - a 2002 Chrysler 300M Special has factory HID's and they don't dim. I already added more grounds in the engine bay, so upon further research I suspect it is the puny battery from Nissan. So yesterday I went and purchased an Interstate MTP-24F battery.
http://www.interstatebatteries.com/c...nths+++800+CCA
Once installed, I took my car out at night, turned on the defrost, wipers, and HID's and bumped my music very loud. No dimming headlights!
For those of you with aftermarket subs and amps, you should really consider changing the factory battery. The Interstate MTP-24F comes with an excellant warranty and it fits perfectly.
Yeah I was always told the Red Top was for cranking, and the Yellow Top was for the Amps, etc because it was a deep cycle battery and if you used it as the primary battery you would kill it prematurely. Interesting that they say run the Yellow Top "everywhere" I wonder if Interstate changed it...?
I'm hearing nothing but good about XS Power so I might just suck it up and re-route some cables. Looks at the specs on the XS Power D2400 and tell me that's not a mean chunk of power! (Also check their FAQ for how they rate their products)
http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-MTP-24F(Automotive+Truck).aspx?dsNavigation=Ns%7eprodu ct+Type%7c101%7c1%7c%2cN%7e21-4294493546-4294493538-2147384909&Title=Mega-Tron+Plus+24F+Automotive+Battery+++85+months+++800 +CCA
For those looking for a budget priced battery to replace the OEM, Advanced auto has a drop in replacement for $104 with core. After using an online promo coupon, I paid $82 before tax.
Its a true drop in replacement Group 35 battery with 800 AMPS - 640 CCA 3 year free replacement 7 year prorated.
I just replaced my OEM battery with it and install took about 10 minutes.
shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_battery-group-size-35-640-cca-autocraft-gold_2130004-p
The Sears DieHard gold is in fact the best battery at $140, however, if you check Consumer Reports you would find better value for battaries at Walmart for $90 which ranked slightly below the Sears Model
The EverStart MAXX-35N (North) is part of the car battery test program at Consumer Reports. In our lab tests, car battery models like the MAXX-35N (North) are rated on multiple criteria, such as those listed below.
Life:Life test measures how a battery endures repeated charge-and-discharge cycles at hot-climate engine-compartment temperatures. The more cycles endured while maintaining a higher voltage, the higher the score.
Reserve capacity:Reserve capacity estimates how long batteries can run a car if the charging system fails.
CCA:CCA performance reflects voltage at our load of half the average claimed CCA for each group size after cranking for 15 seconds at 0º F. We charged batteries at the 14.5 volts that vehicles typically supply, rather than the higher voltage that manufacturers use. Batteries charged at the lower voltage met BCI voltage standards for a fully charged battery.
Bumping an old thread here but I tried searching and this was the closest thread related to my question.
I've been looking on AAP's website and it only comes up with group size 35 for the AutoCraft Gold if I enter in vehicle info. But I know the 24F is a direct replacement as well and it has 700 CCA compared to 640 CCA of the 35. While searching further I came across group size 124R, which has 700 CCA as well but for $21 less than the 24F. The height and length of the 124R are less than the 24F and the width of the 124R is only 1/8" bigger than the 24F. I wanna assume the 124R will fit since it is smaller but I have not seen anyone mention it on the forums. Any thoughts?
Batteries are pretty much standardized. Any battery advertised as size Group 35 will fit. They are not all the same CCA though so you need to search around for one with the CCA rating you want.
I went with the RedTop 35 and it works great...
I want to get a battery with at least 700 CCA since that is what Nissan is replacing the old 550 CCA ones with. The 24F and 124R both meet this CCA rating. I'm just wondering if I can save $20 and go with the 124R instead of the 24F.
Costco used to source batteries from Interstate and re-brand them as their Kirkland Signature label... they now have batteries that are labeled as Interstate on the shelves here. Many think it is likely the same battery, but now Interstate has their label on it. I bought one from another vehicle a few weeks back. Great battery and a good warranty through Costco. My plan when the time comes for the Maxima is to get a Group 24F 700 CCA battery from Costco. Cost should be around $85.
Costco will not install the battery... or at least I do not think they will. I did my last one in their parking lot myself and then carried the bad one in for the core charge refund. My guess is that you will need to re-set your auto up/down windows, and radio stations etc but that should be about it.
Interstate MTP-24F
Interstate MTP-24F
doobadoo
Aug 15, 2015 06:43 PM
