What size speakers in '97 Maxima SE w/out Bose?
Can anyone tell me the size of the front and rear speakers in a '97 Nissan Maxima SE without the Bose system? I want to upgrade as the oem's are deteriorating. The rears look like 6.5"; not sure about the fronts.
Just want to confirm with those in the know.
Coaxil speakers never really deliver a good midbass output. The will always lack at your subs crossover point which most setups is at 65hz where the sub should roll off and the mid picks up. If you have your speaker crossed at say 80hz it leaves a big weak gap between. Tons of 6x9s is really just for show, you can do a simple active or even passive mids and highs setup that will out perform
Lmao
Lmao
I agree w/ the science and reasoning behind why 6.5s > 6x9s but after hearing both in person..... 6x9 all the way...
Now do I run 6.5s? Yes, I'm on the fence still about hacking up my stock setup, esp. since I haven't finished my audio setup...
Go with quality 6.5s all around. I ran alpine 6x9s in the rear before and honestly, compared to 6.5s (especially at higher volumes) 6x9s sound muddy and not as bright and clear as 6.5s.
My personal fav right now for quality and affordiabililty are JL Audio C2-650x all around.
And shouldnt this go in the audio section lol
I also tried some Type R component speakers for the front, thinking they would be an improvement, but they weren't even close. The Infinitys sound much better. You won't get very good sounding bass from them if you install them in the original BOSE speaker enclosure though, so you need a sub (and crossover, if running one amp. Although most head units now should let you filter your front spaekers). What really irked me was teh Alpine tweeters were a little bigger than the Infinity tweeters, so I had to enlarge the tweeter hole. Now that I've gone back to the Infinity set, the tweeters are a little undersized. Looks pretty ghetto
replacing with another oem set is your best bet unless you change your headunit.
You could spend 100-200 on budget component set and get slightly better sq compare to your current stock system but i think thats not worth it if you want it to sound good on a budget you need a decent 4v headunit and a comp set. i recommend hybrid imagines.
They are 6.5" but also known as "over-sized" so they're closer to 6 3/4" but play it safe and go with 6.5", it'll fit, I've done it.
thanks. If I want to put in some Alpine 6.5" speakers in, what amp do you guys recommend? I have A type r sub going to an alpine amp already. Whats a good value alpine 4 channel amp?
i did on mine 6x9 the tech cut out piece at the back so they would fit plus he took out all the little plastic thing that hold the 6.5 in front and also put in 6x9 in the front doors i went with 5 way speakers they are keenwood and i put in a 720 amp also keenwood and boy does it sound clear
Go with Hybrid Audio. I don't own any of their stuff yet, but I've heard Hybrid's speakers in cars. They're giving much higher end expensive audio components a run for their money. Here's a couple of vids i found browsing around on YT.
Not to be confused these are the entry level speakers from hybrid audio
http://store.12velectronics.com/imag...l-speaker-set/
The other vids are subwoofers and higher end comps offered by hybrid
