power seat and windows problem
Old Jan 22, 2011 | 01:17 PM
jav24's Avatar
hi i have a 96 maxima the power windows and the driver seat stop working i search for similar problems and found to check for fuse #18 and # 13 and they are not blown also i i remove the door panel and all the cables are conected correctly so what else could it be ?
Old Jan 22, 2011 | 05:06 PM
Nopike's Avatar
Check the 30 amp fuses in the fuse box located under the hood next to the battery.
Old Jan 22, 2011 | 05:51 PM
DennisMik's Avatar
As Nopike stated, check fuse F under the hood. Fuses 18 & 13 have nothing to do with the seat or windows.
Old Jan 23, 2011 | 11:26 AM
jav24's Avatar
ok i check the fuses under the hood and one of the 30 amp fuses is blown so i replace it and the doors and driver seat started to work but not the windows is there something else that i have to check ?
Old Jan 23, 2011 | 04:04 PM
Nopike's Avatar
Maybe fuse #12 7.5 amp underdash fuse box. Check them all very carefully.
See if anything else is not working lights... anything.
How did the problem start out of the blue? Were you working on something?
Old Jan 24, 2011 | 09:18 AM
jav24's Avatar
well i remove the battery to clean it out and after i put it back the windows started working so i thing it only need it to reset after i fix the fuse cause after i remove the battery and put it back everything started working ,
thanks for all.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
kjm900r
Aug 5, 2015 07:14 AM
