I need your opinion about A/T Flush
okay first of all, my max is at 201000 miles and I want to do a tranny flush. I bought my max at 185k miles and I have no idea if the previous owner ever did a tranny flush. I've read that its a bad idea doing a tranny flush if the tranny hasn't been flushed regularly. is that true? any feedback is appreciated. thank you everyone.
Someone correct me if I am wrong
we need a more analytical thread
http://forums.maxima.org/5th-generat...a-magnets.html
http://forums.maxima.org/5th-generat...nalytical.html
search
search
If it wasn't done regularly (every 30K miles or so) or if you have no idea whether it has been done, then leave it alone.
If the fluid isn't pink and smooth to the touch (take some fluid and rub it between your fingers), then do a drain and fill. You can even go as far as dropping the pan, cleaning the magnet and changing the filter. If you do drop the pan, change whatever gaskets that are there as well.
i talked to a guy who is pro on cars when he did mine
he said that the filter changing thing is BS. he modded my trans so he could drain the torque converter as well and got almost all of the old stuff out and switched it to Royal Purple ATF. i had no idea when the fluid was last changed but im guessing it was years
i know some places use some kind of pressure machine to force all of the old fluid out, that i wouldnt do on a older trans.
It is bad if you change the fluid, not the filter. Replace the filter, use the same fluid if you do a flush. It is something that builds up in the old fluid, not the filter that causes it to slip after a flush. Drain and refill, add some lucas atf additive for extra protection.
So yes, it is true. If the trans hasn't been maintained, don't do a flush now.
FSM says to inspect every 15k miles. replace every 30k miles if u drive in adverse conditions.
Edit:
If its pink and nice looking then leave it alone. If not, then u may want to change it. There are lot of addtional moving parts in an AT.
Its hit or miss.
Edit:
Its hit or miss.
REDinLV
Aug 15, 2024 12:30 AM
RWCreative
Sep 21, 2015 11:01 AM
dvcamp
Sep 18, 2015 10:17 AM
Violator
Sep 9, 2015 10:14 AM
