another fidanza flywheel/clutch?
Old Feb 4, 2011 | 09:35 PM
dnice02's Avatar
ok i have searched and couldn't find a definite answer. I need some suggestions on a clutch, for a fidanza fly wheel on a 5.5 gen with just I/E/H. Anything other than the 350z. I don't wanna have to modify the transmission case in order to make that work. Oh the car will be a daily. Thanks in advance.
Old Feb 4, 2011 | 10:37 PM
1991Maxima1991's Avatar
Hows about the Fidanza Clutch??
Old Feb 5, 2011 | 05:58 AM
dnice02's Avatar
I never seen or heard of anyone running the fidanza clutch.
Old Feb 5, 2011 | 06:17 AM
knight_yyz's Avatar
Toolie
Exedy stage 1 will be fine
Old Feb 5, 2011 | 07:30 AM
dnice02's Avatar
Is there a certain exedy stage 1 that while work with the fidanza? Are they all the same? Sorry for the newb question I don't know anything about clutches.
Old Feb 5, 2011 | 08:23 AM
knight_yyz's Avatar
Toolie
Get the one for the year of your car. 06804a is the part number I think, but double check theory website
Old Feb 5, 2011 | 08:56 PM
rroderiques77's Avatar
Demodded and Forgotten
I didn't have to modify my tranny for my Z33 clutch to fit.
Old Feb 6, 2011 | 06:46 AM
knight_yyz's Avatar
Toolie
^^ did you use the z33 PP? from what I have read the PP rubs a little, but the disk is ok. And if you buy a Z33 kit you have to spend extra on the maxima bearing since the Z bearing doesn't work
Old Feb 6, 2011 | 11:32 AM
dnice02's Avatar
So everyone that uses the oem 350z clutch and pressure plate, don't have to grind down a certain area on the tranny case?
Old Feb 6, 2011 | 02:47 PM
knight_yyz's Avatar
Toolie
BTY the maxima exedy disk has more surface area than the stock Z33
Old Feb 6, 2011 | 02:59 PM
datsunzcar84's Avatar
But if you are using a solid flywheel you should use a sprung clutch disk if you don't want it to engage harsh .
Old Feb 6, 2011 | 03:50 PM
dnice02's Avatar
anyone using the fidanza clutches? are they any good?
Old Feb 6, 2011 | 04:06 PM
NissanTun3r's Avatar
call competition clutch they have a great product and prices and the lightest flywheel available for 5th gens-10.xx lbs
http://www.competitionclutch.com/
Old Feb 7, 2011 | 09:53 AM
rosader's Avatar
I run the Exedy stage 1 with Fidanza flywheel. Exedy stage 1 is MUCH stiffer than stock and I do have clutch chatter but you get used to it. I love the way the car feels with this setup!
Old Feb 7, 2011 | 09:58 AM
Shift_Max's Avatar
I used to run a 350z clutch on the fidanza flywheel and did not have issues with it.
Old Feb 7, 2011 | 03:50 PM
dnice02's Avatar
Did you have to grind down your transmission case to clear the pp?
Old Feb 7, 2011 | 03:53 PM
Grand_hustle17's Avatar
@ the OP- werent you doing a 6spd swap also???
Old Feb 7, 2011 | 06:25 PM
dnice02's Avatar
Yes i'm trying to decide on an affordable clutch kit. have you started on your swap yet?
Old Feb 7, 2011 | 06:42 PM
yea its in the shop, should be done tomorrow or wednesday... there is a group buy on clutch in the classified for exedy clutch for $200 free shipping... i went with that
Old Feb 7, 2011 | 08:15 PM
The whole clutch kit was 350Z with a Maxima throw out bearing. No rubbing whatsoever.
Matt93SE
May 24, 2019 02:58 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
