In Drive with brakes and Still pulling
Old Feb 10, 2011 | 07:36 AM
coolsun's Avatar
So when i am stopped at a light or in traffic, the car still has some pull in it, like i am braking and stepping on the gas. The rpm stays right above 1000 rpm and more brake pressure is needed. It feels like the torque converter is on load which can't be a good thing. It goes away sometimes, like a sticky throttle which it wasn't.
I have cleaned the throttle body and MAF, new EGR, and new hoses. What can be causing me to idle so high? even in Drive. When i shift into park or neutral it idles around 1800 rpm. Can it be my IAC? it was cleaned last year and didnt seem that dirty either. Noob question, is there a slave cylinder in an automatic?
Tanks
Old Feb 10, 2011 | 07:43 AM
Stormzusmc's Avatar
i had an issue like this with a car back in the day, turned out to be the fuel pump - probably not the issue in this case though
Old Feb 10, 2011 | 07:44 AM
RA121625's Avatar
Not entirely sure but whatever controls the idle is probably malfunctioning (stuck open etc). There was also a post about this a while ago, make sure the throttle cable has some slack in it too so that its not still pulling when you let off the gas.
Old Feb 10, 2011 | 09:13 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yea i would look at IACV or something of that nature.. possibly IACV + TPS. 3G's are MAF-based not MAP-based so a vac leak wouldn't affect the engine same way as it does on, say, a Camry.
Old Feb 10, 2011 | 04:27 PM
coolsun's Avatar
Alright, i guess this weekend would be taking out the IACV. Thanks guys
Old Feb 10, 2011 | 06:13 PM
elusivemax93's Avatar
Automatic ve coolsun? Higher idle would say extra unmetered air getting into the air system. Does your idle stay steady or sweep?
Old Feb 10, 2011 | 07:47 PM
coolsun's Avatar
yeah auto!, you don't know how much i adore an auto living in NYC.(well i didn't have a choice when my uncle sold this to me 4 years ago with 80k miles for a grand!)
Yeah my idle is steady, does not sweep, its just like stuck high reving when in park or netrual and a 1000 at D or R
Old Feb 10, 2011 | 07:59 PM
Check your throttle cable both on top of the plenum and at the gas peddle. Look for and where the cable could get caught up on. Also make sure the cable routing is where it should be.
Old Feb 10, 2011 | 08:15 PM
coolsun's Avatar
i dont think thats the prob, cause yesterday i checked that while i cleaned the throttle bottle and the butter fly was moving feely
But this happens sometimes, not a constant thing.
Old Feb 10, 2011 | 08:28 PM
There is an adjuster screw on the idle air control valve.
Old Feb 10, 2011 | 08:52 PM
coolsun's Avatar
i know that too, but i think i will just clean the IACV n then c what happens, too bad it cost $300 new, i would have just bought a new one like the EGR valve on Rockauto for $30
Old Feb 11, 2011 | 01:23 AM
Tell me about it I have to buy one as the previous owner fudged up my adjuster screw. That is on my to replace list.
Old Feb 11, 2011 | 01:51 AM
Maxkiller's Avatar
The adjuster screw will only have an effect on the idle speed if the IACV is malfunctioning. If you do take it off check that coolant still flows through it, if it is blocked then the temp it is reading would be incorrect but generally this will only result in about 1500 idle. Also check your temperature sensor connector.
My car occasionally picks up stupidly high revs when I alternate between octane boosted fuel and normal premium, my guess is its an ecu compensating effect. Stops if I turn the car off and on again.
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Lowered_a33
Aug 24, 2015 04:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
