Heat Guage
Old Dec 21, 2001 | 03:19 AM
khantman's Avatar
Heat Guage
My 89 SE heat guage acts up all the time. The needle goes all the way up into the overheating zone and then just drops down. If I tap on the guage cover it will also fall back into normal range. Is this a common problem since my car is not overheating. If so, what is the repair?
Ken
Old Dec 21, 2001 | 06:42 AM
VE30DE POWER's Avatar
well you can try replacing the gauge temp sensor it maybe bad..the gauge inside the car maybe bad might have to get a whole new cluster assymbly.not sure if you can just replace the temp gauge or not..
Old Dec 21, 2001 | 07:00 AM
Matt93SE's Avatar
STFU n00b!
Wouldn't hurt to check your coolant level. the sensor for that is in the very top of the engine, so if you're low on coolant, it can do stuff like that.
If it's actually in your gauge, I have no clue there.. probably be bext to buy a gauge cluster from a junkyard and swap the gauge/odometer.
Old Dec 21, 2001 | 06:28 PM
Sudesh's Avatar
or..
You could have an air pocket somewhere in the radiator hoses or something..this causes the gauge to act funny. I know this, mine did it until I had to loosen the hose and let it flow a bit, then it was fine.
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
