Chirping from the clutch?
I have a 3.5 swap in my car. I have not driven it since the swap but it has been started and warmed up several times. When I start the car I get a chirping noise from the clutch/bellhousing area. As the car gets warm, it gets less noticiable until the chirping is gone. When I push the clutch pedal in the chirping goes away (even when the engine is cold and the engine is chirping the loudest)....so this would point to the TOB? I am hoping the problem goes away once I get a few miles on the car but I wanted to see if anyone else has experienced this. All of the clutch parts are brand new. Thanks for any input.
i have done a few clutch jobs also and never had that problem either just seems like that could be the only reason for the noise maybe the tob is deffective did you change your input shaft bearing?
I was thinking the same thing
I will do that if it does not go away after driving it a few miles. I just got the brakes blead last night, so I should be able to put a few miles on it this weekend.
My car has the same chirping noise coming from the bellhousing area. I thought it was the ISB, but I think it's just the TOB needs replacement. I know your clutch is brand-new, but my car has been making this noise since I bought it and it hasn't gotten worst.
Maybe you got a defective TOB?
did you inspect the tob to make sure it didnt have a crack or defect on it?? when i replaced my clutch the tob had a crack in it, most likely from one of my stupid friends hanging around the install and dropped it on the ground. anyways, i had to replace mine because it deff sounded like something was broken.
if it goes away i wouldnt worry too much but you wont know for sure till you get that baby on the road!
Do you mind explaining how to grease this lever? Pics would be awesome.
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
carlosvq30
Sep 26, 2015 09:44 AM
