wheel spacer question...
Old Mar 19, 2011 | 08:51 PM
d-mauch's Avatar
Hey does anyone know whats the biggest wheel spacer i can put on my 4th gen without getting extended studs? and will the wheels stick out a noticable amount?? Please give me input. thanks
Old Mar 19, 2011 | 08:54 PM
CustomLowz's Avatar
5mm on stock studs. You will probably not notice the wheels sticking out. Its more for clearance than anything else.
Old Mar 19, 2011 | 09:02 PM
The most you can get is 5mm and they won't make much of a difference. I once tried 8mm's and I needed extended studs.
You can always get bolt on spacers that have extended studs already attached.
Old Mar 19, 2011 | 09:03 PM
d-mauch's Avatar
ok thanks. i actually just found some wheel spacer online that are 1in and i guess they bolt onto the stock hub using the stock studs and the new spacer has new studs pressed in already? H&R and Eibach makes some sets...are you farmiliar with them? Just curious as to how good they are and to how far my wheel will stick out. I want the wheels to stick out but i dont want it to look ridiculous lol
Old Mar 19, 2011 | 09:05 PM
d-mauch's Avatar
Thats what i was just gonna ask about! have you heard of how good they are? I found ones that are 1in. Will that make my wheels stick out too much?
Old Mar 19, 2011 | 09:49 PM
VQ'rInWLA's Avatar
I have some spacers for sale if you need em.
http://forums.maxima.org/general-max...c-spacers.html
Ignore the title. Im willing to ship them now.
Old Mar 20, 2011 | 07:22 PM
What are your wheel widths and offsets?
Old Mar 20, 2011 | 09:49 PM
VQ'rInWLA's Avatar
Old Mar 21, 2011 | 08:19 PM
d-mauch's Avatar
I just recently bought the wheels...they are Konig Rated R's 17x7 and the offset is between +38 and +40 im not sure
Old Mar 21, 2011 | 08:22 PM
d-mauch's Avatar
how were the 25mm bolt on's...will i have to roll my fenders?
Old Mar 21, 2011 | 09:57 PM
VQ'rInWLA's Avatar
It all depends on the tires you get. Also are you dropped?
Old Mar 22, 2011 | 04:54 PM
d-mauch's Avatar
im gonna be putting on 235/45R17 and its lowered 2.5in
Old Mar 22, 2011 | 11:10 PM
With 7" wide rims you're gonna need some thick spacers to make them flush with the fenders.
Old Mar 22, 2011 | 11:46 PM
VQ'rInWLA's Avatar
Exactly OP. Buy both of my spacers, Ill give you a discount!
Old Mar 23, 2011 | 08:27 PM
d-mauch's Avatar
whats a good with to go with for 17's?
Old Mar 23, 2011 | 08:30 PM
VQ'rInWLA's Avatar
My spacers! 25mm is basically an inch! Slap those on the rears. Slap the 15mm on the front and call it a day. Mind you, the rear are sunken in more than the front thus the bigger spacer.
HOKUSMAX
Nov 13, 2017 04:34 AM
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
