Question... About 5.5 gen max spark plugs
Old Apr 15, 2011 | 08:45 PM
95Maxi's Avatar
Hello. Im sure its here in the forums somewhere but , I couldnt find it ..lol..
I want to change my spark plugs .. I bought from nissan oem ngk"s . I see the front 3 but I was told the back 3 . Id have to remove the top part of the motor there is this true and any suggestions for me ?? The help is always appreciated...
Old Apr 15, 2011 | 08:50 PM
MajesticBlue2K2's Avatar
this guide should help
Spark Plug / Ignition Coil Replacement
Old Apr 15, 2011 | 09:06 PM
95Maxi's Avatar
Nice ! Thanks
Old Apr 15, 2011 | 09:09 PM
wiseguy55's Avatar
I followed that exact write-up and was done in about 1.5 hrs. Take your time. Clean your TB while you have it off.
Old Apr 15, 2011 | 09:14 PM
nelledge's Avatar
"I'm just sayin'..."
Grab A34 valve covers beforehand. You might as well change them while the plenum is off. Relatively inexpensive. Just changed mine last weekend. Finally.
Old Apr 15, 2011 | 09:16 PM
nelledge's Avatar
Relevant disclaimer: Research cleaning these TBs before you do it. You don't want to regret incorrect procedure after the fact with these expensive guys.
Old Apr 15, 2011 | 09:19 PM
MizzMaxine's Avatar
Be careful to torque the plugs to the recommended OEM specs
Old Apr 16, 2011 | 02:23 AM
NmexMAX's Avatar
dot dot dot ...
I clean my TB every time I change my plugs.
And don't "lol" because it's annoying.
Old Apr 16, 2011 | 05:28 AM
95Maxi's Avatar
It def seems like a b@#$% to do this job .. How about the manifold gasket should that be changed as well?
Old Apr 16, 2011 | 05:43 AM
nelledge's Avatar
It's not as bad as a 4th gen. Just give yourself time and keep track of the fasteners. All of the electrical connections are color coded or it's obvious where they plug back in. You could also look into getting some spacers from Aaron. The only additional thing you'll have to do is take off the lower intake manifold(LIM).
Old Apr 16, 2011 | 05:45 AM
nelledge's Avatar
How often do you change your plugs???
Cleaning the TB is a definite 'must'. Knowing how to do it properly is as well.
Old Apr 16, 2011 | 12:31 PM
NmexMAX's Avatar
dot dot dot ...
Last time I went with Ir's so it will be a while.
Old Apr 16, 2011 | 12:57 PM
Rods03Max619's Avatar
[QUOTE=nelledge;8013451]Grab A34 valve covers beforehand. You might as well change them while the plenum is off. Relatively inexpensive. Just changed mine last weekend. Finally.[/
Did mine last week, not bad......
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
