throttle body adjustment
Old Apr 29, 2011 | 02:41 PM
sticky's Avatar
throttle plate not fully closed moved tps around to line up holes with holes lined up to get screws in leaves plate cracked open, how do i adjust where holes line up and plate fully closed
Old Apr 29, 2011 | 04:32 PM
Gizm0's Avatar
I wouldn't mess with the throttle body if I were you man... these drive by wire TB are very sensitive, trust me, I fuc|<ed on up recently and had to buy a new one...
Old Apr 29, 2011 | 08:43 PM
mahanddeem's Avatar
that's if he has DBW......However even the cable TB adjustment shouldn't be messed with.
Old Apr 29, 2011 | 10:36 PM
NAVY00MAXIMA's Avatar
Sometimes adjustment is needed. The bracket holding the TB adjustment nuts and threaded cable end can bend slightly and not allow full WOT and give excessive pedal play.
Old Apr 30, 2011 | 03:27 AM
sticky's Avatar
tb is off the car for cleaning,i got the tps on with t-plate closed but the tps is angled down a bit the old one was like strait level,mabe thats why it was surging and would only go to 1800 rpm
Old Apr 30, 2011 | 11:01 AM
mahanddeem's Avatar
and til this very moment , we don't know whether you have a 5th or 5.5 gen !!!
Old Apr 30, 2011 | 01:35 PM
STICKY SAID IN A PREVIOUS POST -hey all i have an 01 max a/t trying to get back right,replaced iacv,tps,rebuilt ecm,idle is perfect but when i give it throttle it surges real fast up and own whether it is in park or in gear,the only fault im getting is 430 cs left bank,would this cause this surge? thanx
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
