Smog Woes for 95 Nissan Maxima - Detailed
Old Jun 11, 2011 | 12:10 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Hello
I hope someone has ideas on what the problem can be. My mods are MEVI,Ypipe, intake, and Greddy SP1 catback. I have a JWT ecu but removed it before the first smog test.
I have failed smog 4 times now and each time it is due to high nox. I have no clue on what it can be right now.
Before the second smog check, I changed the PCV and used Guarantee to Pass. I failed the 15mph test. I had the smog operator conduct a diagnosis and he stated that the EGR is working properly but is not opening all the way due to low backpressure from the catback. He stated that the catalytic converter was bad.
Before the third smog check, I had a new catalytic converter installed and it failed even worse on NOX. The new cat was universal and there does not seem to be any leaks.
Before the fourth smog check, I had the EGR tube and EGR valve cleaned, they were pretty dirty but it failed smog on the 25mph test and barely pass on the 15mph test.
There is a check engine code on now which just came on recently but the code is for the KS and the rear O2 sensor behind the cat. My obd2 reader shows the car going into close loop when I am driving and back into open loop when I am idling. I am assuming the top two o2 sensors are functioning properly.
Can the greddy catback cause a low back pressure environment where the EGR valve won't open all the way or is it a lazy valve? I have check all vacuum and there appears to be no leaks. So right now, I am at out of ideas. Any help will be appreciated.
Thanks.
Old Jun 11, 2011 | 12:45 PM
99greddymax's Avatar
Put your stock ypipe back on, change the cats o2 sensor and you should be golden.
Old Jun 11, 2011 | 12:54 PM
asand1's Avatar
Nox is the result of high compression chamber temps. How hot are you running? Lo backpressure could cause low EGR flow. Get a cheap exhaust tip and crimp it flat.
Old Jun 11, 2011 | 01:00 PM
Iilac's Avatar
Car operating temperature appears to be fine. What are the normal ranges for chamber temps and how would i go about measuring it?
Old Jun 11, 2011 | 01:21 PM
asand1's Avatar
Don't know x2. Make sure your not too lean. Restrict your exhaust a little. And make sure your cooling system is right.
Old Jun 11, 2011 | 01:22 PM
asand1's Avatar
Not comletey closed off, just restricted.
Old Jun 12, 2011 | 04:36 AM
Leo_Koneval's Avatar
Yeppers, high NOx is a result of high temps.
Maybe a good EGR cleaning would help clear out the lines. Or maybe running a little rich would cool things down. But then your hydrocarbons might go up.
I can't believe I'm already forgetting the exhaust basics I learned a few months ago. I think I'm getting old.
Old Jun 25, 2011 | 06:24 PM
Nismo's Avatar
any updates?
Old Jun 28, 2011 | 03:47 PM
Rods03Max619's Avatar
Damn it in the same ucked up state for smog.....but isn't that bad where I go I pass NP bit now got a problem for the smog coming up...though...
Old Jul 11, 2011 | 05:47 PM
Iilac's Avatar
I wanted to give a update. Car finally passed smog. I pour in Chevron synthetic techron in the fuel tank and seafoam the intake maniford and it passed!!! +1 for seafoam.
Old Jul 12, 2011 | 11:08 AM
98SEBlackMax's Avatar
Maxima.org Insomniac
Did the KS ever code go away or is that still around?
Reason I ask is that I recall when I failed smog for high NOX and HCs the KS was bad so I replaced it and it passed. Even with an aftermarket Y pipe and a OEM type cat, I let the car idle for 15 mins before going into the smog check and it made it through.
Old Jul 12, 2011 | 10:31 PM
Iilac's Avatar
No, the KS code and O2 sensor code is still around. I think the KS code is triggered by the O2 code and the O2 code came on right after my cat. converter was replaced.
Old Nov 19, 2011 | 03:55 PM
Nismo's Avatar
did you ever pass?
Old Nov 19, 2011 | 04:07 PM
Iilac's Avatar
Read post 10 members only jacket wearing manhandler!!!
Old Jun 8, 2015 | 05:50 PM
Iilac's Avatar
Passed another smog test but after passing the test in 2011, I had it registered in a county which only requires sniffer and not the dyno which is way easier. I still barely pass this year. My HC was at 99 at idle and maximum allowed is 100. I been reading up on the TC-W3 additive and gonna try it on my ole Max.
Old Sep 2, 2017 | 07:00 PM
Iilac's Avatar
Ole Maxima failed again due to high HC on the 2500 rpm test. It failed by 1 point. Fml.
Old Sep 23, 2017 | 11:46 PM
Iilac's Avatar
Update, I was able to pass by using Seafoam in the brake booster and 2 cans in the gas. I need to remember to do that before each smog.
Old Jan 2, 2018 | 12:18 AM
Nismo's Avatar
did it pass?
Old Jan 2, 2018 | 10:02 PM
Iilac's Avatar
Originally Posted by Nismo
did it pass?
Old Oct 12, 2018 | 09:36 PM
Nismo's Avatar
Did it pass?
Old Oct 16, 2018 | 05:04 PM
Iilac's Avatar
Did it pass?
U gonna jinx yourself and your max won't pass smog.
Old Jan 10, 2022 | 06:06 PM
Nismo's Avatar
Did it pass?
Old Jan 10, 2022 | 08:50 PM
schmellyfart's Avatar
lmao
Old Jan 10, 2022 | 09:04 PM
95naSTA's Avatar
x2
Old May 23, 2023 | 10:41 AM
Iilac's Avatar
Did it pass?
lmao
Originally Posted by 95naSTA
x2
I put the Maxima on non-op after the last update, it just sits on the street most of the time. Reminds me that I need to wash it and wax again. I still keep up on the maintenance of it but it's an extra vehicle at this time.
I dunno what the temperature is, it doesn't overheat. Car still runs great and I wouldn't hesitate to drive it across the Country. I have to keep this in mind if I decide to register it. Thanks for the advice.
Old May 23, 2023 | 02:50 PM
I'm sure you are aware, but a non-op vehicle can't be parked on a public street. Be careful, a neighbor may report it to your local police department, and then PD will issue you a ticket.
Old May 23, 2023 | 04:00 PM
Iilac's Avatar
I do know this and thank you for the warning.
Old May 24, 2024 | 06:44 PM
Nismo's Avatar
Did you get a ticket yet?
Old May 25, 2024 | 10:14 AM
Iilac's Avatar
spgview
Jun 22, 2014 02:40 PM
mbb6
Jun 26, 2007 07:20 AM
roastduck88
Aug 4, 2006 07:18 AM
probmxstyle
Jan 18, 2004 07:42 AM
Confused
Aug 11, 2002 09:29 PM
