Reverse lights LED
Reverse lights LED
I was wondering which LEDs you guys use for reverse lights?
I have stock lights and want something brighter, but don't want to spend a lot of money on it.
Pictures would help too. Thanks
my 99 maxima wouldnt work with LED's in the reverse lights. They would flicker, but they wouldnt stay ON
I used 921 bulbs, found them pretty quick and easy on eBay.
You can find any bulb code you need using the guide here.
LED's are more intense but not brighter than filament bulbs; they generally have a narrow output angle. I can tell you from experience that if you put LED's back there you will not be able to see much of anything behind you at night (unless you find some super power LED's from somewhere, like close to 1 Watt or something).
Also, make sure you get LED's that have a "stem" or no light will get in the reflector and the bulb will be useless.
Example of "stem"
Example of a flat bulb that you don't want
Example of "stem"
I use 20 SMD 1156 bulbs in white. They're 360 degree LEDs and they're pretty bright. I had HID reverse lights at one point which were the **** but I blew a ballast and sold the bulbs to a friend. Whenever I get a new kit the HIDs will be going back in.
not exactly answering your question, but here's a little sumthin sumthin i did with led reverse lights. just wanted to share my idea with you guys since the topic is up. the output is pretty good. strips from the zone. easy splice job.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
p.s. queenambeach luv ur sig lmao
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]p.s. queenambeach luv ur sig lmao
The SMDs I got right now are pretty good, but yeah, LEDs usually not bright in far distance. I was also wondering, I have seen LEDs on ebay for like $100 that are SOOO BRIGHT. Do you know how they make them? Is it possible to find those cheaper?
I can't find the link now, but they were on ebay and had youtube videos. REALLY BRIGHT REVERSE LED LIGHTS
those old school super white bulbs by polarg worked just fine for me back in the day. http://www.racinglab.com/polm6hypwhit.html
have ya looked at http://www.superbrightleds.com/vehic...ulb_finder.php ? i wanna get the foglamp leds for my i30. hope this helps.
MaxLife17
Jun 27, 2019 01:37 PM
jds22
Sep 4, 2015 01:52 PM
