5spd wont go in any gears when engine running
Old Aug 16, 2011 | 06:28 PM
highonfumes's Avatar
i just did a 5spd conversion everything is bolted up done car runs when the car is off it goes in gears when its on it wont go in ****t now now im thinking a dragging clutch cause its out of adjustment and is probably not fully bled the pedal has alot of freeplay but it is stiff i need responses please wanna know if anybody else had this problem maybe (oh and slave, master, and clutch all new) thanks
Old Aug 16, 2011 | 06:31 PM
TLMNICK's Avatar
Your clutch isn't fully disengaging when you put your foot down. That will prevent you from putting it into gear. If you have a lot of freeplay, then that means that your slave is hardly moving.....which means your pressure plate is hardly moving. That'll be the best place to start looking.
Old Aug 16, 2011 | 06:45 PM
luke95gxe's Avatar
check master cylinder resivor could have a leak in one of the hydralic line seems to be common
Old Aug 16, 2011 | 06:55 PM
nope nothing dry checked that already
Old Aug 16, 2011 | 11:54 PM
TravisCadello's Avatar
look at the slave cyl and see if its being fully pressed in while pumping clutch pedal if not gravity bleed the clutch system some more and if it still dont fix change clutch master cyl.
if all is working maybe u didn't install the throw out bearing and fork correctly.
Good luck!
Old Aug 17, 2011 | 11:48 AM
cashoit's Avatar
slave cylinder.
Old Aug 17, 2011 | 11:51 AM
asand1's Avatar
Might also be cracked clutch fork, disk installed backwards, or large enough debris on the clutch facings. If you installed an OEM line, they can be a bish to bleed.
Old Aug 17, 2011 | 04:43 PM
no new slave clutch disc s right way no crack in fork ss line
Old Aug 17, 2011 | 04:47 PM
yesterday i had no gears wen car was on now we bled it a lil better and i got to go in gears when the car is on NOW THE PROBLEM IS it is grabbing on the floor the clutch is grabbing on the floor and everyone is saying bleed it tomorrow when i back in school my next step is either use the macine to flush and bleed or use the vacuum im thinking vacuum cause when i was leaving i started to bleed but i couldnt finish cause it was time to leave and i had work sooooooooo IDFK WTF WTF WTF WTF IM GOING CRAZY HELPPP! thank u
Old Aug 17, 2011 | 04:49 PM
and when it was grbbing on the floor we drove it out to the lot and it went thru evry gear fine no problem other than the fact it grabbing on the floor
CorollaULEV
30
Aug 9, 2021 08:11 PM
rtirbany
Sep 8, 2015 11:46 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
