NEED ADVICE..07 max no bose stock system
so my 07 max without bose with the stock 6x9 subwoofers in the back are going bad.. what are my options of replacement?
im having a hard time finding 6x9 subwoofers so im thinking of replacing them to mayb 8, 10 or 12.. apparently the stock ones are 2ohms
can i go with 4 ohms subs will it affect the sound negatively and also what brand should i go with?? im totally clueless give me a few ideas on setups i do not want to change the door speakers or the stock headunit
if you want just a replacement, i would look into tang band. they make 6x9 subwoofers.
http://www.parts-express.com/pe/show...number=264-837
only prob is that they're 8 ohm...you wont get much power out of the stock amps. i would just get a dedicated 10" (or hell even an 8") subwoofer in a simple enclosure to augment your bass response. but this route will be bit more costly.
thanks everyone for your replies...
the audio guys i went to claim that the rear deck were not subwoofers and that they are speakers and crutchfield.com says that in the rear deck:
"The factory woofer(s) in this location receive only bass frequencies from the amplifier. If replaced with aftermarket speaker(s), the aftermarket speaker(s) will only reproduce bass"
im looking at this setup right now i think they might work... wat do you think?
http://www.amazon.com/Infinity-6929I.../ref=de_a_smtd
and as far as an amp..
http://www.amazon.com/Kenwood-KAC-15.../ref=de_a_smtd
im thinking i might not need the amp if that statement above is true
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
