Transmission going bad?
I have a 96 SE 5spd with 96,xxx miles. A couple of days ago, I started hearing a humming noise coming from the engine/transmission. It starts to get real noticeable around 70MPH. It sounds like a bearing gone bad and its dependent on vehicle speed not RPM. When I'm cruising and hold in the clutch to let the RPMs drop, the sound stays the same. About 4 months ago I rotated the tires, changed both axles, and replaced pads and rotors all around, and I've driven a couple thousand miles since, so those things are ruled out. Is is common for a 4th gen manual tranny to go bad under 100k miles? The car is all stock and rarely gets beaten on. I dont even like downshifting to slow the car down.
I can accept if I need to get a new tranny, just dont want it to happen right now while I'm going to school.
I just hope I have the option to rebuild it before I get stuck somewhere. BTW, lifted my car today and everything in the front end is nice and tight. It was really hard to tell if the tranny was making noise though, cause of all the other noises I gotta fix first.
If the noise is speed dependent and the above two things check out fine...you have one or more defective wheel bearings.
Edit: Also, did you change the MTL when you did the axles and what did you use?
I'm gonna say wheel hub assembly as well. that happened on my old eclipse. I used the slide hammer to get it off and it came off in 2 pieces and the bearings were crushed.
Just an update
It was the wheel bearing. Thanks for all your replies. It was mostly the driver side one, left some brown spots here and there due to heat. I replaced both though, including the seals. I would say it took a good 2.5 to 3 hours to do at the shop I work in using a lift and air tools. I had to use a bearing tool though because we don't have a press.
Just outta curiosity, I checked All Data and the labor time is listed at 5.1 hours. One of the perks of my job is using the lift/equipment at no charge
Old Bearings:
One of the new bearings packed:
Old Bearings:
Mar 12, 2020 12:06 AM
Melissa40
Jun 30, 2017 10:04 AM
The Wizard
24
Oct 1, 2015 08:47 PM
ColdCananda
Sep 20, 2015 10:45 PM
