Underbody aero kit prototype idea
Old Sep 21, 2011 | 12:41 AM
infinimax96's Avatar
I had an idea the other day about what an underbody aero kit for the 4th gen would look like. I know they serve multiple purposes such as reduce drag, create down force and even help fuel economy a bit. I did some research and couldn't find many examples of people constructing any front and rear defusers as well as mid sections underneath the car to help draft air from front to back.
I've seen tons of these on STi's, Evo's and other cars but was curious to see how well a set up like this would work and look on a Maxima. So over the next few weeks I'll be constructing a prototype from cardboard and installing it to see what it looks like. I'll post pics of the finished product and if I like it I'll be building a permanent one from a durable material.
If anyone would be interested in adding one to their Maxima and all goes well with the prototype it's possible I could put a kit into production. We'll see how it goes. If anyone has any suggestions on final building materials or if they have examples I'd love to see them.
Old Sep 21, 2011 | 04:40 AM
Quickywd01's Avatar
I'm interested in seeing the results. I've seen a member here use masking tape to cover the rear bumper/spare tire area on the track and it improved times.
Old Sep 21, 2011 | 06:54 AM
riseanew's Avatar
lemme help
Hey, bro. Sounds like a good idea. The concept is definitely valid, however I'm curious about how low this would be when installed. Clearance seems like the only issue.
Either way, I'm studying mechanical engineering at N.C. State and have some Solidworks (similar to AutoCAD) experience. I'd be willing to help you with this and do some computer design concepts of your final design.
Also, we have a wind tunnel where it's possible to do drag tests of your design but on a smaller scale. We actually tested a modded 2009 Dodge Ram, slammed with a full body kit and a stock 2009 Corvette, both scaled to 1:18. The drag coefficients were almost identical which suggests a major improvement in aerodynamics to the Dodge. I don't have a scaled maxima butwe could work around that. Cool idea tho. Keep us posted.
Old Sep 21, 2011 | 07:10 AM
zero2sixtyZ's Avatar
You embarrass me.
There was a 5th gen owner who made a rear diffuser.
http://forums.maxima.org/5th-generat...er-making.html
Old Sep 21, 2011 | 07:22 AM
ajm8127's Avatar
http://forums.maxima.org/8165524-post102.html
Old Sep 21, 2011 | 01:02 PM
that rear diffuser looks sexy. That's almost exactly what I'm going for. I'll keep everyone posted on what I come up with in a week or so.
Old Sep 21, 2011 | 01:37 PM
Ninja1058's Avatar
very interested in this, cant wait to see the results
Old Sep 21, 2011 | 01:47 PM
MAXIMA_STYLE's Avatar
In to see results... would this cover under the entire engine and rear of the car?? Maybe interested pending final outcome and product design....also for durability....i know as far as weight something non metal but to withstand rock and road debris....idk maybe something similiar to the lip kit material ?
Old Sep 22, 2011 | 05:31 AM
hornepirate's Avatar
I was actually going to make one of these over summer but ended up not having enough time to fab on and test it. I was going to use plastic cardboard for a template and then make a fiberglass mold of it
Old Sep 22, 2011 | 05:38 AM
std aja de's Avatar
Pixell
looks like a good idea.
Can't wait to see when it's finished.
Old Sep 22, 2011 | 07:36 AM
mista0406's Avatar
Subscribed waiting on outcome
Old Sep 22, 2011 | 08:51 AM
Bassman.357's Avatar
i wanna to see it too
@ Ajm, I saw the pics in that link, it a cool fab project, but it looked quite bulky
Old Sep 22, 2011 | 10:30 AM
Prophecy99's Avatar
keep us posted
Old Sep 22, 2011 | 03:22 PM
Final product would either be aluminum or fiberglass. If you have the money it could even be done in carbon fiber.
Old Sep 22, 2011 | 03:42 PM
Nissanserguy's Avatar
fiberglass would be cheap. Hell if it looks good I may jump on board and try and fab one myself. I live in your area
Old Sep 22, 2011 | 04:15 PM
I noticed you are from UT. I live downtown. We should get together and draw up a design. I could use some help with fiberglass work.
You own a 4th gen Maxima?
Old Sep 22, 2011 | 04:21 PM
Very interesting.
Old Sep 22, 2011 | 04:52 PM
Yeah I live out in Kearns. I know a guy who does lots of glass work, built a body kit a while back.
Yeah, own a 99 Pearl white Maxima. should be in my sig
Old Sep 22, 2011 | 09:29 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
I was the one who had 2J Racing install the front splitter/under tray. The front splitter works well, makes the car more stable at highway speeds and helps the fuel economy a little bit. Weight of the whole thing is around 10 pounds with the brackets and panels. The material is alumilite, as it can survive the abuse but its fairly light. Fiberglass and CF won't work as they would crack on the first sharp bump the splitter hits. Also if you cover the underside (or box up, as they say) of the engine bay make sure to create some way for the air to get out. 2JR boxed in the transmission and the airflow was stagnant on the driver's side and the engine bay got a bit to hot, so I ended up cutting off some more of the panel to let air out. I could of also had air vents installed into the hood but I did not want to go that route.
Sometime in the future I will work on a rear diffuser with the stakes and what not. Since it sits higher and won't get impacted as easily fiberglass or HDPE panels will be used to construct the diffuser.
I use it for the track and not much else, its so low that it can't be used on the street to easily but highway driving is fine.
Old Sep 22, 2011 | 09:37 PM
We should get together for sure then. Always love another pearl white Maxima shoot me a text sometime 801-856-5287.
I use it for the track and not much else, its so low that it can't be used on the streets.
I saw your thread linked. I like the front splitter on your Max. I wasn't planning on making the front out of a fragile material. That would = recipe for constant cracking and scraping on dips.
I'm starting construction next Tuesday and will be working throughout the week. I'm starting from the back rear diffuser and working my way to the front. I'll post pics of my cardboard mop up when I get done. Keep in mind it won't be a final product, just a prototype to build a more permanent solution.
Old Sep 22, 2011 | 11:34 PM
QT1 5MT AE's Avatar
Gram Lights addict
there is a member on the .org that makes both CF front and rear diffusers. expect to pay a pretty penny.
Old Sep 23, 2011 | 02:40 AM
Carbon fiber is not the only thing they can be made from. Sure it's durable, light weight and looks awesome but there is other materials that can easily get the job done without spending hundreds of dollars.
Down the road you can always use the cheap alternative until you have the funds to dump into a carbon fiber upgrade and use the old one as a mold to weave a new one out of carbon fiber.
Old Sep 23, 2011 | 03:33 AM
GGENIUS's Avatar
so wheres the OP's prototype idea? i see nothing from him yet.
Old Sep 23, 2011 | 06:13 AM
ajm8127's Avatar
It's only been two days, cut the guy some slack.
Old Sep 23, 2011 | 07:15 AM
stokerdevil666's Avatar
susbscribe very interested in this any idea how much this kit would cost total i mean i understand it's bthe begining stages but ruff idea <$500>$1000 for you non mathematical peoples that under 500 or greater than 500 but under a 1000
Old Sep 23, 2011 | 08:00 AM
My brother has an evo and his car has a rear one. We're gonna take it off and just see how it looks on the back and if it can be mounted, and if it can we're gonna run it up little cottonwood for a drive on some corners
Old Sep 23, 2011 | 09:44 AM
J2FRESH's Avatar
i've been thinking of having a CF rear diffuser made myself lol a local member out here has one on his Black 4th gen and its ****
Old Sep 23, 2011 | 09:53 AM
J2FRESH's Avatar
is he local to us, i think i know who it is.... i always wanted to ask about a rear diffuser cuz i seen it on a black max out here in cali but if its the person i think it is he's always busy lol
Extreme Dimensions
http://www.extremedimensions.com/3390.html
i was planning on buying one myself since i never seen a maxima with it until now^ lol im still going to buy it tho
Old Sep 23, 2011 | 12:10 PM
GGENIUS's Avatar
i wasnt talking **** yo? im interested.
Old Sep 23, 2011 | 12:45 PM
Get some pics of it on his car.
Old Sep 23, 2011 | 01:00 PM
Grimmrezx's Avatar
very curious on how this will turn out cant wait to see the final product
Old Sep 23, 2011 | 01:22 PM
Like I said a few posts back: I won't be able to do a mock up until Sunday or Tuesday. I work 50+ hours a week so it's difficult for me to find time to do anything. Be patient and I will post something.
J2FRESH's Avatar
he rarely comes out to our meets but if he comes out or if i see him ill snap a pic real fast while he's not looking
Old Sep 24, 2011 | 02:36 AM
I got all my prototype materials ready and have a simple draw up of what I have in mind. I should get some pics up Sunday when I get the time to start this project. Sorry for the delays everyone. Patience and I will deliver.
Old Sep 25, 2011 | 02:30 AM
Kingcordero's Avatar
infinimax96 let me know if you need a test lab rat car or any help you got my digits
Old Sep 26, 2011 | 10:39 PM
If you aren't working tomorrow I could use some help.
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
Pied
Sep 26, 2015 03:29 PM
zmcneely13
Sep 26, 2015 02:26 PM
Socalstillen
Sep 26, 2015 12:01 PM
