Lil dilemma
Old Sep 26, 2011 | 01:56 PM
MAXIMA_STYLE's Avatar
Lil dilemma
Ok so i recently bought a 99 se-l most of you know i got it pretty well modded and DIRT cheap..it was jeffersons former max from jersey... anyhow... most know 99 are all cali emission cars and this is no different however back in 04-05 a butterfly valve screw let go and popped the engine.. it was then replaced with one from a 97 FEDERAL emissions and a cattman fed y pipe also installed.. now im throwin codes for swirl valves and obviously all the o2 sensors because those arent even there .. my question is this... if i were to run the fed spec o2s on the ypipe and install an ecu from a 97 fed spec 5 speed(if its a direct mount) would this solve my problems?? Or do i need the entire engine bay harness installed with the ecu??
Old Sep 26, 2011 | 02:32 PM
asand1's Avatar
Just from reading I think you'll be okay wth just the ecu and swapping a couple wires in the harness plug. Not sure about the sensors.
Someone with experience in this will chime in I'm sure.
Old Sep 26, 2011 | 03:55 PM
i need to find a diagram for the two different ecms and someone that knows a little more would probably be good to help me out too
Old Sep 26, 2011 | 05:08 PM
2000_MAXIMA_KING's Avatar
You're going to do all that just for the O2 sensors
Just run an O2 simulator, look up Symtech Labs their simulator can be run on primary O2 sensors and you can even tweek the output signal to the ecu into whatever is needed to simulate the exact sensor for your car. Its easy to install and easy to use I just installed one on my secondary sensor yesterday.
Old Sep 26, 2011 | 05:14 PM
BenL's Avatar
For the ECM terminal layout, the FSM link (for both) is in my signature if you need it, for 1999 it's EC-108 through EC-115 (pages 110-118), for 1995-1998 it's EC-95 through EC-104 (pages 95-104). It has the pins numbered on the first page and what the numbers represent on the pages following it.
Old Sep 26, 2011 | 05:23 PM
Not just for o2s i need to pass emissions eventually... swirl valve codes wont let me pass in my state...therefore a fed spec car has no swirl valve therefore no codes....and thanks benl i didnt even think fsm at first i got the 99 fsm on my comp....
Old Sep 26, 2011 | 10:50 PM
DennisMik's Avatar
I have a pdf file with the pin numbers and signal names. It has a column for each of the 4th gen years (95-99) for side by side comparison. If you are interested, pm me with your e-mail address and I'll send it to you.
tsi6001
Oct 3, 2022 10:23 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
carlosvq30
Aug 17, 2015 11:32 AM
crsmax
Apr 17, 2001 12:58 AM
