P1441/P0400 (vacuum cut valve bypass valve?)
Can anyone provide a picture of where the vacuum cut valve bypass valve is on a 97? Or a solution to this.
I keep getting P1441 P code. And now a P0400 to go with it. note: codes only started coming after highway drives at high speeds and only after the mechanic replaced knock sensor! could it be ecu problem? ive cleared the code three times now to be sure but yeah every time i hit high speeds for a while it comes back.
note: i looked at FSM and the diagram doesn't really help =S nor did the diagram on CourtesyParts...
That valve is located behind the drivers side rear wheel. It's between the charcoal canister and the gas tank.
http://www.aa1car.com/library/evap_n...ntb00-085a.pdf
The bottom left corner of figure 1 will show you what it looks like.
nice alright. now where can i find this for our cars. lol. :s i might as well just replace it? i mean ive looked on most parts sites but basically because the name varies in so many ways its hard to find the right one.
easier than replacing the EGR valve which my mechanic wants to do :s
magiconthetire
Oct 26, 2015 09:03 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
