P0744 tcc circuit intermittent
Old Oct 20, 2011 | 05:26 PM
maxed_out_99's Avatar
sup org.
heres the deal, my 4th gen trans took a dump before that i had this code along with all sorts of other problems
the trans, tc, and valve body have been replaced with 5th gen goodies
this is not really common from what i have experienced but anyway heres what it does
after i start it cold or warm the first shift into tcc lockup works and is fine as if nothing is wrong but after a bout 2 minutes of lockup it disengages and doesnt come back on until i shut it off and start the car again
if anybody has any clues hints or tips i would appreciate it
thanks org
Old Oct 21, 2011 | 07:17 PM
i hope i didnt **** anybody off somehow
maybe its just a tough one
any knowledge on this matter would really be helpful
thanks org
Old Oct 21, 2011 | 11:49 PM
vqmaxman's Avatar
Are you getting any SES lights on and is your harness pins connected. I woulld get the code scanner and check the codes. I would check the voltages on the harnes pins and the solenoids packs that are in the valvebody adn are the packs new.
Old Oct 22, 2011 | 02:07 PM
Yes, yes, and yes
I have not voltage dropped the connector but the old one was cracked and broken so I de pinned and re pinned a junkyard all weather pack
Now if I was to voltage drop it wouldnt the tcm have to comand the solenoid on to get the proper reading?
I did check the resistance of the trans fluid temp sensor cold and hot and it seems within spec
Old Oct 25, 2011 | 11:36 AM
bumpskis
Old Nov 3, 2011 | 09:52 PM
Back from the dead
still looking for some tips
Old Nov 3, 2011 | 10:41 PM
vqmaxman's Avatar
I am sure that the 5th gen solinoids are different than the 4th gens. I would believe that the TCM would also be having trouble engaging the VB sol properly due to the 5th gen packs. The best way to figure out if it's the 5th gen packs and the TCM. Do the o/d on/off test the instructions are in the haynes or chilton manual or the forums. The VB,sol packs are diffrent from what the TCM for a 4th gen would recognize.
Old Nov 4, 2011 | 10:10 AM
It was doing this before the swap though
I will defiantly check that out thanks
Old Nov 5, 2011 | 12:43 PM
ok, so i did the o/d blink code and found something interesting
3short 4 alternating long blinks 2 short and 1 long
i have no clue what this means i hope someone can shed some light and help me track down this problem
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
AaronL
Nov 15, 2020 11:52 AM
mikeg75
Nov 30, 2015 05:12 PM
