NJ *BRAND NEW* Lincoln Easy Mig 140
This unit is brand new and never opened, it comes still packed in the original box.
Price: Asking $560
Local pick up only but I will meet within a 25 mile radius, however I will not meet in New York City
Here are Lincoln's specs
Lincoln® Easy Mig 140 K2697-1 120 Volt AC Input Compact Wire Welder
Whether you have a home project, farm repairs or basic autobody welding to complete, the Easy-MIG™ 140 should be at the top of your shopping list! Requiring common 120 volt input power, the Easy-MIG™ 140 can be used almost anywhere. With simple two **** tapped control, the machine is easy to set up for gas-less flux-cored welding for deep penetration on thicker steel or gas-shielded MIG welding on thin gauge steel, stainless or aluminum. Compare the precise drive, rugged construction and full list of standard accessories. . . Lincoln® Easy-MIG™ 140 is an excellent choice!
FEATURES
• Forgiving arc makes dialing in your application easy.
• Smooth arc starts with minimal spatter.
• Wide 30-140 amp welding output range.
• MIG weld 24 gauge up to 10 gauge (.135") sheet metal in a single pass. Weld up to 5/16" steel using self-shielded Lincoln® Innershield® wire (FCAW-S).
• Precise Wire Drive features:
• Precision full adjustment drive system reduces chance of wire tangling and crushing.
• Brass-to-Brass gun connections for enhanced connectivity.
• Large industrial closed-design drive motor for improved torque and trouble-free performance.
• Spool Gun Ready -- add the optional Magnum® 100SG spool gun for reliable operation at the high wire feed speeds aluminum welding demands. No expensive outboard modules required.
• No Hassle Tool-less Design -- for wire spool mounting, wire drive service and polarity changes.
• Innovative contact tip, drive roll and nozzle storage -- keeps all your consumables close at hand
• Power Chassis™ channels airflow to cool power systems, structurally secures key components and traps wires and cables to avoid unnecessary abrasion.
• Toughest PC Board Protection in the industry -- 'Potted' to seal sensitive components from the environment, 'trayed' in a tough plastic tray to add rigidity and shock resistance.
• Three Year Lincoln® Warranty/90 Days on gun and cable assembly
INCLUDES:
• Magnum® 100L gun and 10 ft. (3.0 m) cable assembly
• .025" (0.6 mm) Contact Tips (Qty. 3)
• .035" (0.9 mm) Contact Tips (Qty. 3)
• Gasless flux-cored nozzle for Innershield® welding
• Gas nozzle for MIG welding
• Spindle Adapter for 8" (203 mm) Diameter Spools
• .025" Drive roll for MIG welding
• .035" Drive roll for MIG welding
• .030"-.045" Drive roll for Flux-cored welding
• Shielding gas regulator and 10 ft. Hose
• 2 lb. Spool of .025" (0.6 mm) SuperArc L-56 MIG wire
• 1 lb. Spool of .035" (0.9 mm) NR®-211-MP flux-cored wire
• Work Clamp and 10 ft. (3.0 m) Cable
• Welding Handshield
• Instruction Manual
• Instructional DVD
any questions please ask
Price: Asking $560
FEATURES
INCLUDES:
• Instructional DVD
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
