Stuck JICs
Stuck JICs
One of my front JIC strut cartridges is stuck and will not thread up or down in the bottom of the coilover. I tried to thread it down via the threaded nut that the spring sits on since it tightens down on the second threaded nut and should turn the whole assembly but it will not budge. PB blaster didn't help either.
I did notice a hex just past the adjustment **** on the bottom of the strut cartridge. Is that what this hex is for?
I just wanted to make sure since it's a pain in the ***** to get to with the axle in the way.
Just went through the same thing due to dust/sand. Take the coilover assembly out and use leverage to turn the body. Pulling the coilover out is a LOT easier than trying to work under the car. Takes a few minutes with air tools, no more than half an hour in and out with hand tools.
Cheater bars are your friends. I didn't need to use a solvent to loosen the threads, but you may need to depending on how severe it is. Remove the threaded body completely and thoroughly clean both threaded surfaces. Be sure to apply some anti-seize compound before you thread it back together to prevent it from happening again.
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
