hard start unless i disconnect the battery
Old Nov 20, 2011 | 02:56 PM
smai555's Avatar
then it will start fine for half a day or so then it gets hard to start, then i disconnect the battery for a bit and its starts right up happens at any temp as i have tried the combinations doing it cold hot etc seems like reseting the ECU is the "fix"
the hard starting has been going on for a few weeks i have been troubling shooting i have replaced the CTS, Crank sensor (pos), ignition switch, when back to the stock air box, fuel pressure is correct, no codes but i didnt check for ghost codes
any thoughts on why it will start okay on a ECU reset but not when its been running for a while
Old Nov 20, 2011 | 07:03 PM
Maxima_Joe's Avatar
4th Gen Parts King
Everything you described is a grounding problem. Does it push start fine?
Old Nov 21, 2011 | 06:38 AM
cashoit's Avatar
i would grab a spare ECU from the JY. Seems like thats the issues especially if u keep havin to reset.
Def check grounds too
Old Nov 21, 2011 | 07:27 AM
wirelessdude04's Avatar
Def sounds like a ground, clean the old grounds up if you want add a grounding kit. Process of elimnation
Old Nov 21, 2011 | 12:02 PM
smai555's Avatar
yea i had a ground straight from the starter bolt to the neg, (so i ruled it that out) but i swapped it out away with a 4 gauge one and it started right up seems fixed for now thanks guys
The Frye
Sep 2, 2021 11:03 AM
ballerchris510
Sep 10, 2015 09:35 PM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
