How do I identify and LSD transmission
Old Feb 2, 2012 | 06:40 AM
benjie's Avatar
If you have one in front of you, what are the visual and physical indicators that a transmission is LSD?
Manual of course.
Old Feb 2, 2012 | 07:50 AM
JNCoRacer's Avatar
Just the tip.
The drivers side axle seal is bigger than a non VLSD.
Old Feb 2, 2012 | 07:59 AM
aackshun's Avatar
The differential is open (makes no sense but trust me), nothing in the middle of it (eg. you can stick a pole through the diff where the axles go).
Old Feb 2, 2012 | 08:05 AM
DanNY's Avatar
Ad·min·is·tra·tor
lift up both front wheels...
spin one wheel in one direction...if the other wheel spins easily/smoothly in the opposite direction then it's open diff.
Old Feb 2, 2012 | 08:08 AM
aackshun's Avatar
True, but at this point in time most VLSD's have failed, and you can have a former locking VLSD transmission but it no longer does it's deed any more.
Also IIRC.
If your maxima is from the U.S. you do NOT have a VLSD.
Only Canadian maximas had VLSD.
As for I30s.... Different story...
Old Feb 2, 2012 | 08:36 AM
benjie's Avatar
So here's the rest of the story. I thought I bought an lsd transmission from a junkyard on Tuesday(30 day warranty). VIN on the tranny is JN1CA21D6WT529728. I ordered an axle from Rock Auto. EMPI part number 804598. If you go to nissanpartsasap.com and enter in the VIN above, you get that it's a 98 Maxima manual. Last night I get the axle and I go just to make sure the axle fits and it won't go in all the way.
I think there might be a pin the middle where the axles meet so I'm guessing it's not lsd. I can't remember and waiting for someone to send me a picture to verify. So now I have to go get my money back and look for another tranny.
Old Feb 2, 2012 | 08:46 AM
nycspudz03's Avatar
Yea..it's not an LSD ..I had the same exact issue with a local junkyard.Tried to pass it off like it wasnt a regular open diff. O had to raise hell!
Old Feb 2, 2012 | 08:56 AM
aackshun's Avatar
Yeah A LOT of yards have no idea wtf they have.
Old Feb 2, 2012 | 08:58 AM
benjie's Avatar
Just confirmed, pin through the middle.
Not LSD.
At least that explains it.
Old Feb 2, 2012 | 09:01 AM
SHIFT_maxboost's Avatar
i checked into that a while ago and i thought i found that theres a tag on it somewhere that identifies it. the vlsd had an extra letter at the end or something but dont quote me, it was a manufacturer sticker next to the metal id tag. of coarse yours may be gone as mine was in terrible shape. hope this helps
Old Feb 2, 2012 | 09:03 AM
cardana24's Avatar
Blown
It will say "LOCKER" on the side j/k
if you have another transmission to compare it to, the driver side axle hole is a lot bigger than the non locking diff. and the other easy way to tell that has already been stated is looking though one axle hole and being able to see out the other side. The vlsd driver side axles are harder to put in than a non vlsd axle, so I would not base everything off of the axle not going in right away. Check the other two obvious things first before you give up on it.
Old Feb 2, 2012 | 09:05 AM
aackshun's Avatar
Yes it's like R5F50A (something like that) vs R5F50V the V means locking or A means open.
A small metal plate on the tranny identifies it, I may be able to grab a pic when I get home.
Crusher103's Avatar
damn people are still asking this question?
Old Feb 2, 2012 | 09:06 AM
aackshun's Avatar
I know, but it's good to have one recent clear and concise thread, lets just spoon feed em for now.
Old Feb 2, 2012 | 09:11 AM
Crusher103's Avatar
Im not to sure about this one, on my VLSD and my open diff the actual axle hole is pretty much the same and i can see right through both from one side to the other with no obstructions. Getting into that is getting a little bit too specific.
The best way to tell is on the driver side on a VLSD there are 2 sets of splines you have 1 set than a different set for the actual locking of the differential further inside the diff.
Old Feb 2, 2012 | 01:20 PM
Nealoc187's Avatar
SLOW
RS5F50V or A
Old Feb 2, 2012 | 01:47 PM
A is non-vlsd and V is vlsd
Old Feb 2, 2012 | 05:08 PM
maxfever1987's Avatar
Also IIRC.
Part of wat u wrote is wrong, the correct info is SOME u.s.a maximas had vlsd not all but some
Old Feb 2, 2012 | 11:44 PM
Nealoc187's Avatar
SLOW
i think he was just talking about 95-99s.
Old Sep 22, 2016 | 01:40 PM
Terry Welsh Sr.'s Avatar
Infinite i30
If I don't have limited slip on my 1999 infinite does that mean I don't have a locking diff? Wold that make it an A or B transmission.
Old Sep 22, 2016 | 03:23 PM
maximaxi's Avatar
Locking diff = LSD
If you don't have limited slip, you don't have locking diff.
Check the tag under the hood, at the passenger's side, there's a plate there, at the firewall, ot has the VIN number,
Look where it says transmission. If it ends in an A, it's LSD. If it ends in V, it's not.
Example:
Old Sep 23, 2016 | 08:52 AM
Originally Posted by maximaxi
Locking diff = LSD
You said the part in BOLD backwards....
Old Sep 29, 2016 | 11:18 PM
asand1's Avatar
Here
Originally Posted by asand1
The vast majority of 5spd Maximas are open diff. Most LSDs are autos. In Canada manual LSDs are more common though. I have an open diff manual.
The VIN plate on the firewall includes the Transmission code.
RS5F5OA=5MT open
RE4FO4A=AT open
RS5F5OV=5MT VLSD
RE4FO4V=AT VLSD
Old Sep 30, 2016 | 07:57 AM
lux97Max's Avatar
Sure the id plate is one way to check, however people can swap transmissions out and not put the correct back in. VLSD has to look like this
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Pied
Sep 26, 2015 03:29 PM
