Why wont my engine light turn on?
Old Feb 14, 2012 | 07:47 PM
midnight0045's Avatar
I've been driving without my 3rd o2 sensor plugged in for a while now (as a result of recent exhaust work) and I have no cel. wtf? The light turns on when turning the ignition past the ACC position.. so the ODO bulb can't be burnt out.. thoughts?
Old Feb 14, 2012 | 07:54 PM
Rods03Max619's Avatar
This is a 1st someone wants a CEL, I would just be Happy that its not on, but on the exhaust o2s, some get lucky and dont get one and some do...how many miles have you driven on it since....
Old Feb 14, 2012 | 08:29 PM
lol I dont "want" it but driving completely without the o2 sensor after the cat? If everyone could do it they would.. but no one does. some "trick" the ecu by installing a dummy resistor.. just not sure why the light isn't on. and to answer your question almost 100 miles driven and haven't noticed any major change in gas mileage.
Old Feb 14, 2012 | 08:37 PM
RA121625's Avatar
Did you actually just start a thread complaining about how you want your CEL light to come on?
Old Feb 14, 2012 | 08:51 PM
Originally Posted by midnight0045
lol I dont "want" it but driving completely without the o2 sensor after the cat? and to answer your question almost 100 miles driven and haven't noticed any major change in gas mileage.
IIRC, that O2 just monitors the front two. You probably won't throw a CEL and you won't notice any change in gas mileage or performance.
Enjoy not having that little annoying light on as long as you can. We all hate when it decides to pop up.
Old Feb 14, 2012 | 10:00 PM
asand1's Avatar
100 miles isnt very much, just wait. The after cat sensor only monitors cat efficiency, it wont affect mileage or driveability. A resistor isn't enough, it requires an ever changing signal. Real simulators are a signal generator of sorts using a 9V battery.
Old Feb 14, 2012 | 10:16 PM
ShocknAwe's Avatar
Its a tricky light. Some people just don't get them for whatever reason. Probably a faulty 02 in the first place so when its gone nothing actually changes as far as ECU feedback. My o2 codes simply went away after a week or so and that was only after a y and a muffler install. Once new headers are made in a month or so, my amber friend will come back around I am sure
Old Feb 14, 2012 | 10:34 PM
maxed_out_99's Avatar
Take it to advanced auto an have them scan it you may just not have a code have them look at the pending history also
Old Feb 15, 2012 | 07:48 AM
thanks for the feedback guys I'll have it scanned then I wont f-ing worry about it lol
Old Feb 15, 2012 | 08:04 AM
Phromethius's Avatar
This is soooo what I'm going to call it if it ever comes back again. lol.
Old Feb 15, 2012 | 09:08 AM
99zx2's Avatar
everything that was said above. if it ever comes on (usually anywhere between 100-150 miles), get two spark plug foulers (get the right mm size for the maxima) and drill one of them with a 1/2" bit, then screw the undrilled on in that one, then screw in the o2 and plug this whole thing in. the idea is to move the rear o2 farther away from the gases. you might need to drill the second one also, but with a smaller bit, if the tip of the o2 is hitting it.
or get a tune to disable the rear o2 altogether.
Old Feb 15, 2012 | 09:42 AM
morris369's Avatar
There are certain perameters that have to be met for the ECU to check the rear 02's for cat effieceincy. It will come on eventually. The spark plug non fouler trick does work well, but depending on your placement, it might not have the room. I did it on my last truck when I hollowed my cats, no more CEL
Old Feb 15, 2012 | 03:23 PM
max-r95's Avatar
My 02 sensor on cat is bad and it was on for a few thousand miles, one day it turned off and I never saw it again
Old Feb 15, 2012 | 04:24 PM
tigersharkdude's Avatar
Matt, does the engine light come on when you turn the key to ACC? Maybe the bulb is out...or removed
Old Feb 16, 2012 | 08:18 PM
He said it turns on in the first post homie
Dennis Twohy
Oct 1, 2015 06:01 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
