I Have Started To Change Timing Belt Myself. Questions...
I Have Started To Change Timing Belt Myself. HALP!
Ok so I decided to change the timing belt myself...I am using this guide here:
http://www.caraudiohelp.com/nissan_m...e_tutorial.htm
Many thanks to the author
I am at the point where I need to find TDC. I am looking at the crank pully wheel standing in front of the engine looking down (standing over the passenger fender area). Which mark on the pully indicates TDC? I see five or six marks on there, and I want to be exact when finding TDC. Thanks!
EDIT: I just read saw that write up, and that's a method I've never used when replacing a timing belt. Anyway, there is 5-6 notches on the edge of the pulley which allows you to set the base timing. The write up refers to the farthest mark on the left (0* BTDC)
Just because the timing mark on the pulley (or crank gear) is lined up DOES NOT mean the no 1 cylinder is at TDC! The pulley mark (or crank gear mark) only indicates TDC once every two rotations of the crank shaft. There for, besides lining up the timing mark (or crank gear mark) you MUST make sure either the distributor points to no 1 cylinder or the cam marks are lined up as well.
Thanks for the help guys,I appreciate it.
Now I am at the part where I need to remove the alternator belt. But the alternator seems to be unmovable. I loosened both the alternator bolt and the tensioner bolt all the way, but the alternator won't move, thus I can't get the belt off. And tips?
Ok I got all the drive belts off. The toughest one was the alternator belt because the bolt on the top was so torqued that the alternator would not swivel on the tensioner..but I got it loose finally
So now I am disconnecting the radiator hoses and removing the timing belt cover
Ok so now I am trying to remove the top timing belt cover...damn its a *****. There is a metal AC hose blocking the edge of the cover from clearing the left cam sprocket. Then there is a metal coolant device blocking the top of the timing belt cover...why the hell did they design it this way? So frustrating!!
Also, I gave up trying to remove the crank pully wheel. I used an impact wrench with max torque 250 foot pounds. The bolt did not budge. I am assuming I can still install the timing belt without removing the the crank pully wheel though right?
Here's the problem..if I try to pull the cover out, the metal pipe (on the bottom of this picture) blocks the cover from fully clearing the left sprocket.
But If I try to pull the cover up, that round metal thing (at the top of the picture) blocks the cover as well! Even trying the massage the cover out, those two issues still block it!
I also realized that the crank shaft pulley needs to me removed in order to remove the lower timing belt cover. So I am gonna spray some PB Blast on the bolt and let it sit over night...because right now even my electric impact wrench is not successful in removing that bolt.
If that doesn't work...
http://www.youtube.com/watch?v=O_6SFBg7_dg
at work i helped a guy do the timing belt on a old BMW, we had to use the breaker bar/starter method. worked fine, took around 10 tries and we got it, whoever touched it last put a ton of loc-tite on it
Which coil wire do I need to unplug first though?
Ok I finally was able to remove the upper timing belt cover...I had to remove the thermostat assembly first, then it was very easy to remove the upper timing belt cover.
I was also able to remove the bolt holding the crankshaft pulley...it took some PB Blast overnight an few more tun with the impact wrench. The bolt came off, but the pulley wheel is still stock on. I am assuming I need a puller of some sort right?
Also, I was looking at the left and right cam sprockets...there are no indicators on it to find TDC. I see no white lines or indentations anywhere on the sprocket. ANy help here?
Yes I am a VE guy but I do know this much about the VGs that the marks are on the back plate for the cover or the head (which ever is behind the sprocket). Oh and yes you will need a harmonic balance puller (easily found at any autoparts store. Oh! when you do get it off I highly suggest inspecting your crank key (the notch on the crank to align and hold the crank pulley in place). The ones on the VG are known to break therefor screwing up your timing. About the equivalent to timing belt breaking.
Look at the picture of post #3 of this thread and it shows that the camshaft gear will have a punchmark at one of the teeth and the cover plate behind it will also have a punchmark. You will see that for both camshaft gears. When you have both cam gears lined up along with the crank gear lined up, it will be at TDC.
There is two problems with this statement. First, the pulley and crank sprocket each have their own key so if the pulley key were to break it wouldn't have any effect on the timing belt. Secondly, a broken pulley key is super rare and I've never even heard of a broken sprocket key. More often than not the crank sprocket is completely stuck to the crank, requiring its destruction to remove. Twice I've had to drill holes into crank sprockets and cut them with a cut off wheel until I could get a breaker bar to snap it into 3 pieces to get them off. It must be removed to replace the crank oil seal, which is highly recommended while you having the timing belt off!
La Zona Imagery Im guessing your working on a 91SE, in which case you have the square tooth timing belt with a 60K change interval. Late 93 and newer VGs have a round tooth belt that has a 105K change interval. The belts are about the price, and the conversion can be done for less than $50 (around $10 if you were already planning on replacing the crank sprocket)
Both the round and square tooth crank sprockets are the same price (~$33). Used round tooth cam gears can be picked up from a junk yard or e-bay from any 94+ VG for ~$10. I think its a great conversion for someone who wants to keep their car for a long long time, or a great selling point.
Thanks for the tip Maxpwer..I might just go ahead and covert to round tooth since I am planning on pulling the cam sprockets to replace the oil seals.
But I got a problem....I can't for the life of me locate the TDC marks on the current cam sprocket. Here's a picture of my right cam sprocket...can anyone locate the TDC mark?:
BTW yea Maxpwr, I am working on a '91 SE...reason I am putting so much time into it is because it has sentimental value to me.
As you can see, its all oily and grimey inside the timing belt area. I am assuming leaks everywhere.
Could the little line at the 1 o'clock position o the sprocket be the TDC mark?
Edit: This cam gear isn't super clean as its an old square tooth, but I cleaned it up a little bit so you can clearly seen the punch mark.
Thanx for catching that.
Thanks for the help Maxpwr...
Ok so I think am at TDC right now...can anyone confirm? I want to make sure:
Right cam sprocket
Crank gear
Distributor
Problem is, I can't see anything on the left cam sprocket..it's too dark to see any marks there. But can I be assured of TDC just judging from the above pics?
Right cam sprocket
Crank gear
Distributor
Ok so I took the old timing belt off.
Now I am trying to put the new timing belt on..damn its tough! I tried doing for an hour, and I couldn't get it on
Any tips?
I installed a new tensioner and spring...should I have installed this after putting on the new belt instead? Because right now, the new belt is very hard to get oo the sprockets.
Any tips?
If you haven't already, it's a good idea to install the new water pump before the timing belt. Getting a timing belt wet with anti-freeze will reduce it's life and its almost impossible to avoid while its on. While you have the belt off its also the only time to replace the oil seals for the cams and crank.
It helps to take the tensioner off the stud while you install the belt. Just make sure the white lines on the belt match each punch mark and you know you have it installed correctly. Then you can reinstall and tighten the tensioner. Before putting the timing cover back on, start the car and let it run for a few minutes. During this time you should listen for any unusual noise like rubbing or squealing which likely means you over tightened it. Once the car cools down check the deflection of the belt according to the FSM
Or are you having trouble getting/keeping everything lined up? The belt you have has 3 white lines on it showing the proper location of each punch mark for installation right?
Where did you get the timing belt from? Did you get it specifically for the maxima or another VG powered car? I think the belt should have 144 teeth, but thats from memory so I better double check that.
The problem i am having is getting the belt to align at all 3 points at the same time. When the belt is aligned at the top two cam sprockets, it seems as if the belt is half a tooth short from aligning at the crank shaft. I am trying tp ull it to align but it won't budge.
I am using this belt:
http://www.autozone.com/autozone/par...60628_16098_0_
it's 133 teeth
yeah i took the tensioner off and tried install the belt first...no luck...maybe this belt is too tight?
it's 133 teeth
Ok here's a picture of my problem...the lines on the belt are aligned correctly with the punch marks on the two cam sprockets. But it seems impossible for me to align the bottom white line to the punch mark on the crank sprocket. The red arrow I have drawn corresponds to where the white line on the belt is. As much as I pull on the belt the gear won't reach into the correct valley of the belt.
