Removing the headlight on my 97 Maxima, can't figure out how?
Old Feb 29, 2012 | 05:13 PM
Terror's Avatar
I need to remove the headlights on my 97 Maxima as I want to replace them with unfoggy, clear ones. I can't find the screws or bolts to take out the headlights? Am I blind? Any help appreciated.
Old Feb 29, 2012 | 05:16 PM
tigersharkdude's Avatar
Refer to my sig....
Old Feb 29, 2012 | 05:23 PM
Terror's Avatar
Thanks for no help, I've searched first clearly, and googled, nothing but vague tutorials that mention 4 screws. I can't see anything on the front, side or back.
Old Feb 29, 2012 | 05:27 PM
I found this in 5 seconds..........searching
http://forums.maxima.org/4th-generat...eadlights.html
Old Feb 29, 2012 | 05:28 PM
95Maxed's Avatar
Terror, its me from Reddit. lol
So to take them off this is what you do...
Unbolt your side clearence lights.
Then there are two bolts that you will clearly see. Unscrew them.
Second, look near the radiator. Staring at the front of the car on the grill end of the head light there will be two bolts. Youll need a socket with an extension in order to unbolt them.
Old Feb 29, 2012 | 05:29 PM
Pop the hood.
Remove the screws at the top of the corner lights.
Take a small flathead screwdriver and pop out the ***** out of the sockets behind the inside corners of the corners.
Behind the corners you will see two 10mm head bolts. Remove them both.
Behind the headlights, closer to the radiator, there are two holes each with a 10mm nut behind them. Remove them both.
Take a flathead and pop off the grill tabs that are attached to the inner headlight upper corners.
Start pulling and remove the headlights.
Reverse this process to reinstall.
sickwitit's Avatar
remove the corner light, its 1 screw when you pop the hood, two screws exposed right there when u remove it, other 2 are behind the headlight on the inner side of the light by the grill
sickwitit's Avatar
wow, i like the 3 responses at once ^ lol
Old Feb 29, 2012 | 06:25 PM
SandyMax96's Avatar
Don't forget to remove the grill, since I believe it's mounted in front of the headlights with a clip like apparatus though it may just be on my car since it's been smashed in 3 times and counting...
OP, also remove the "headlight protection black shroud" that covers the left headlight in front of the coolant reservoir, just to unplug the bulb from the harness.
Long sockets are a must, as everybody else has stated, and possibly removing the relay top cover on the right headlight might access you some extra room.
Good luck, and don't forget to use BlueMagic to make them foggy free!!!!!!!!!!!!!
halfpol
Oct 17, 2022 12:16 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
acw
Aug 13, 2015 12:50 AM
13Maximasv
Aug 7, 2015 10:56 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
