HID light sometimes not working
My HID in headlight (ONE SIDE) sometimes does not turn on. I thought it was ballast, so I replaced the ballast with another OEM ballast, but still have same problem.
Can bulb does that? or its something with wiring?
It's probably the bulb. When in doubt, replace those first especially if you have OEM ballasts. Those rarely go bad.
To be sure, swap the bulb from one side to the other. If the problem moves over to the other side, it's the bulb. If the problem stays on the same side, it's time to check the wiring or maybe the headlight fuse.
Dennis Twohy
Oct 1, 2015 06:01 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
