Trailer Hitch.....OUCH I Know...
Ok, I know I am going to take a bunch of crap for doing this, but I'm willing to risk it if it means I get some feedback. I am going to have a trailer hitch put onto my '01 Aniv. I was curious if anyone else out there has done this and where they went, (ie. dealer...U-Haul, how much they paid, and if the car has been decent? Thanks.
-Keith
-Keith
Re: Trailer Hitch.....OUCH I Know...
-Keith
-Keith
-Keith
-Keith
I also looked at the Hidden Hitches, but their tongue weights were a little low (@100lbs vs 200lbs for the Draw-Tite). The do look better, but my Bike Rack requires a 200lb tongue weight fully loaded.
Originally posted by costcowholesale
what are you going to tow thats less than 1000lb? the max is only rated @ towing 1000lb
Stereodude
Re: ummm, did you?
Originally posted by TimW
that was 'MS 2K1 AE' who said that, not Kelton.
All I know is you better budget in a tranny cooler install if you actually plan on towing *anything*.
positive feed back here.....
i got a hidden hitch on my max GET IT dont get a draw tite looks like azz with a draw tight you see the whole bar across the back of the car with the hidden hitch all you see is the square recever which is like 1x2 looks really nice with the cover they give you hardly can see it, as for towing i tow my trailer 3x8 plus my 850 lb 500 auto artic cat so probaly about 1000lbs althoughter no problems as of yet even pulling up hill just dont use 5th gear or bye bye trany
Hope that helps
Hope that helps
Hope that helps
Hope that helps
http://home.cinci.rr.com/thekratzers/Maxima/bikes.jpg
http://home.cinci.rr.com/thekratzers/Maxima/hitch.jpg
Originally posted by jkratzer
I also have a Hidden Hitch(brand name) and I agree that this is the way to go with the Max for esthetic reasons. The only thing is the Hidden Hitch is a deep recessed receiver hitch, so I had to buy an extension to use my bike rack(visible in the first pic).
Hope that helps
Hope that helps
I really don't want to make the back of my beautiful Max look bad, but it seems as though the Draw-Tite is the safe bet.
I believe I have a draw-tite hitch (though I could be mistaken, there is no label on it anywhere) and there is no bar across the back. It is V-shaped and mounts to the front side of the back bumper and the wheel well.
I have a rac'n'lock bike rack with an extension that I made so I can haul three bikes. I didn't have any problems. I am not sure how much the rack weighs (guessing about 50lb) but my bike is 23.5 lbs (alum frame, marzocchi fork, shimano xtr all the way, so its light) my wife's bike is 29 lbs, and the other bike was heavier than hers. So probably about 140 lbs total.
As for towing a trailer, if you have an auto, you probably want a trans cooler. If you have a 5speed, dont worry about it. I would stay under 2000 lbs, and definitely keep the tongue weight under 150 lbs.
I know the max is rated for 1000/100, but that is very conservative (for a standard trans).
I was looking a putting a hitch on my 00 Max for a bike rack. Be very careful, i'm not sure what you got if it is an 1-1/4" than be careful. The U-Haul and Draw-Tite are the same hitch, the under rated 1-1/4" class I hitch will NOT fit a bike rack, the corners are rounded on the inside of the hitch so you can't use a class II tongue in a class I receiver. Don't let them tell you that it will, like I said be careful.
Be warned though: If you leave the plastic cap on, then water that gets in the receiver has no where to go, and the inside WILL rust. Obviously you want the plastic cap on, otherwise the hitch looks pretty horrid on the back view of the car. So what I do before I put the rack in is spray wd40 inside the receiver and spread oil on the part of the rack that goes in. I wont go into detail about how hard it was to get the rack out before I discovered I had to do this...
I had my dealership put one on my 98 Max 5spd. I don't know the brand but it must be close to the hidden hitch style because you can only see the reciever if you look at it when crouching. It doesn't destroy the look at the rear. I'm going to have one put on my wife's 2k2 auto as well. I've towed 1600+ lbs with the 5spd (trailer and 2 motorbikes) with no problem, lots of power easy 140 kph on the highway. A little worse gas mileage of course. I wouldn't think you need a trans cooler for the auto if you stay below 1000 lbs. What do you guys think?
CorollaULEV
30
Aug 9, 2021 08:11 PM
