GA 4th Gen IACV adapter plate
For sale: adapter plate that bolts to the 4th gen IACV - allows you to run the 4th gen IACV when doing a 00VI or 3.5 swap.
$60 shipped
I also have an IACV block-off plate for the 5th Gen throttle body for sale.
$60 shipped
Yes, the holes are threaded. You use the OEM bolts that attaches the IACV to the intake manifold. I don't know what codes you are getting, but this allows you to run the OEM 4th gen IACV with the 00VI swap. The 5th gen IACV which is attached to the throttle body can be used but its iffy at best with the 4th gen ECU and people complain of rough idles. I also have a 5th gen IACV block-off plate which works tandem with this 4th gen IACV adapter plate. If you are going to use the 4th gen IACV and the 5th gen throttle body, you have to remove the 5th gen IACV and replace it with a block-off plate. Just let me know.
Hey. How soon could you have one available? I'm in desperate need for one. I'll be able to pay hopefully today, but I just would like that info on how soon you could have one available. Thanks man! Got recommended by Fauken and saw your quality.
stuff man
