Any reason to go w/ clear used OEM headlights or new aftermarket?
My original headlights are pretty cloudy at 200k miles and I found a pretty clear set of used Nissan headlights for the same price that I can get a new aftermarket pair from Rock Auto. I am leaning towards the original for fitment but am thinking the newer ones will stay clear longer. Anyone ever compare the two?
Of course if his paint job is still excellent, waxxed regularly, then go for it.
His sig does say paint so crappy....
DW
As also mentioned above id refinish them. I've done it and it works great. Oem I believe are glass, right??. So if u go aftermarket they'll def be plastice which soon thereafter will cloud up again
95-96 are glass
97-99 are plastic
Both look completely different and have very different beam patterns.
I had a set of TYC 97-99 on my old 96. The beam pattern compared to the OEM lights on my 98 was night and day. The OEM pattern was much better. I parked them side by side and couldn't believe the difference. If you don't want to retro, OEM is they way to go.
97-99 are plastic
95-96 are glass
97-99 are plastic
97-99 are plastic
I hear you - just doing it for sake of visibility though. I'm wondering if any liquid products will slow down the aging process (not sure how much it would be to put 3M clear bra on it).
yeah i noticed that after. Most parts sites separated the fitment into 95-96 and 97-99 for some reason. The other difference is the pattern which may affect brightness, but probably only matters if you'll retro:
Pic stolen from another thread (95-96 on bottom):
And here's the before/after. R/R the headlights is 1 screw 2 bolts and 2 nuts per side - grill unclips and pulls out (though my hamburger fell off, need to get a new one). The difference in headlight brightness was notable.
BTW the lower nut behind the passenger light is a PITA due to the AC line being right behind it. I used a small 1/4" ratchet w/ a normal (not deep) 10mm socket - point the ratchet handle down to have clearance to turn. Tried every set of wobbles/extensions I had and that simple setup is what worked.
you dont need to just replace everything you have a problem with. the emblem can be taped back on, just like it is originally. and you couldve gotten your old ones sanded and re-cleared and they wouldve looked better than new and better than polished. for like the price of a polishing kit.
I did tape it back on, 3M stuff they use for side skirts, non-touchless car wash took it right off.
I have a 1-month old at home, time is scarce. The $ was worth it to me. I have tried polishing before with different compounds/plastic-x and it was marginal improvement that didn't last.
right thats why i didnt recommend that, i recommend getting them clearcoated.
you need to get ALL the old tape off the grill and the badge, and clean the surfaces VERY well. prep is what makes doublesided tape work well.
For that you have my utmost respect
Anyone know where you can buy 95/96 Maxima etched glass headlights new?
They tend to have the best beam pattern. The 97-99 are cool to look AT, but that's it. I know. I saw a 97-99 maxima with 95/96 lights once and it didn't look bad at all. Didnt make the car look older, which I thought it would.
I'm seriously considering downgrading my 98s to the etched glass version. It's either that or spend bucko dollars on projector HIDs like the Chrisman, and I don't exactly have money to burn. Sigh....mods.
DW
DW
Looks like new glass lenses are really hard to come by - your options will mostly be from people parting out and considering the age/reliability of the model you're likely going to see some pretty weathered examples. The aftermarket replacement headlights for 95-96 are plastic but with the same etching pattern rather than the mostly-clear 97-99.
I'm going to look into upgrading the headlamp harnesses and then maybe go to a higher wattage 9004. Right now I have the Xtravision bulbs which, with the clear lights, is "supposed to be" the best completely stock light output.
Dennis Twohy
Oct 1, 2015 06:01 PM
JoshG
Sep 5, 2015 10:10 PM
